Activity › Forums › Apple Final Cut Pro Legacy › highest bit depth with FCP
  • Christina Rule
    February 20, 2009 at 1:58 am
    oh no jeremy I was saying that I am the one making the uncompressed. Basically this is how it went
    UNREAL =images seq which went to comp
    Comp took it in to fusion and then exported it out of fusion (as an image seq i think) and make it a qt movie “none” from a pc. everything is fine with the colors. They give me te “none” everything is still good with the colors. Since my final output it uncompressed 8 I take the none and export it as uncompressed 8. That is where i get my issues. The uncompressed 8 looks worse then the Sorenson. I did do a few tests i exported it out of AT, I took it into FC on a uncompressed 8 seq and exported it. Nothing seems to work
    http://www.christinarule.com
  • Christina Rule
    February 20, 2009 at 2:02 am
    I just changed the sequence settings /video processing from REnder in 8-bit YUV to ALways render in RGB and it does look a little better. But still not like it should. Does that sound like something that might effect this? What is the “render all yuv material”
  • Jeremy Garchow
    February 20, 2009 at 2:07 am
    [christina rule] “Since my final output it uncompressed 8 I take the none and export it as uncompressed 8”
    How did you do this step is what I am asking. Qt conversion? QT movie?
  • Jeremy Garchow
    February 20, 2009 at 2:10 am
    [christina rule] “Does that sound like something that might effect this?”
    No, you sholdn’t do that as 8 bit is a YUV codec.
    [christina rule] “What is the “render all yuv material””
    That’s for processing effects in float (32bit)
    Jeremy
  • Christina Rule
    February 20, 2009 at 2:12 am
    I did it in Quicktime. But then after seeing the results I took the NONE into finalcut and placed it in a uncompressed 8 seq and did file export quick time.
    After seeing that and not being happy with it I took the none file into a “none” seq. and then rendered it using quick time conversion.
    I also did this again but using compressor.
  • Jeremy Garchow
    February 20, 2009 at 2:19 am
    [christina rule] “I did it in Quicktime.”
    I would expect that there.
    [christina rule] “I took the NONE into finalcut and placed it in a uncompressed 8 seq and did file export quick time. “
    Not Quicktime Conversion, right?
    Any chance you can post 2-3 seconds of the ‘None’ Quicktime probelm area to yousendit or a website or something?
    Jeremy
  • Christina Rule
    February 20, 2009 at 2:22 am
    I did do one quick time conversion.. I remember doing another one but I will do it again should I use compressor? Or whats the best way?
  • Jeremy Garchow
    February 20, 2009 at 2:29 am
    [christina rule] “Or whats the best way?”
    The best way would be to have the guys give you a 2vuy movie so you don’t have to recompress, but, you should try what I outlined before, this time with spell correction:
    Open FCP, import the pc “none” render and then make an 8 bit Uncompressed timeline. Drag the fusion file in the timeline and hit no when FCP asks to change the settings. hit render and let it cook for a few seconds then hit cancel. Navigate to the front of the timeline and check out a part of it that has the blue render bar above it on a proper monitor (not your computer monitor). Is it still banding?
  • Christina Rule
    February 20, 2009 at 2:58 am
    Its still there. Not as bad but still there.
  • Christina Rule
    February 20, 2009 at 3:00 am
    the comp guys shoudl give me 2vuy movie? what is that? oppose to the none?
Page 3 of 8
