Activity › Forums › Apple Final Cut Pro › when I select imported mov, unattached audio also moves with it
Posted by Ty Ford on October 23, 2017 at 7:02 pmHow do I keep the audio from moving?
It’s not highlighted.
Ty Ford
Want better production audio?: Ty Ford\’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford\’s BlogJeremy Garchow replied 8 years, 10 months ago 4 Members · 12 Replies -
Noah Kadner
October 23, 2017 at 7:04 pmNot exactly sure what you mean- can you add a screenshot.
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops
XinTwo – FCPX Training -
Ty Ford
October 23, 2017 at 7:55 pmHey Noah,
Thanks for the helping hand.
When I try to move video the audio below it that isn’t even selected also moves with it.
These are totally separate files. The video is a converted ppt that’s an mov.
The audio is a narration. I imported them bot separately and now need to slice and dice to sync them up properly.
When I grab the video file, the audio file below it acts liked they are connected and wants to move with it.
Regards,
Ty
Ty Ford Blog: Ty Ford\’s Blog -
Jeremy Garchow
October 23, 2017 at 9:36 pmHold the tilde key to keep connected clips where they are while moving the clip in the primary.
Noah Kadner
October 23, 2017 at 11:22 pmHmm- you know that’s normal behavior for the magnetic timeline right?
Noah
Ty Ford
October 24, 2017 at 12:18 amGuess not.
What a huge problem when you’re trying to slide audio against video to sync voice to words on a page.
Is there something to click on to stop that?
Regards,
Ty
Ty Ford
October 24, 2017 at 12:19 amThanks Jeremy, that’s a good tip, but these clips are NOT connected.
Regards,
Ty Ford
Jeremy Garchow
October 24, 2017 at 1:36 amCan you please post a screen grab?
If the clip is not connected, it must be in the primary? If it’s not in the primary, it’s a connected clip? If the clip is in a secondary, and there’s audio on it, then the audio is embedded to the clip (and perhaps the audio is expanded). Maybe you are viewing in audio lane mode, where the audio is sorted by Role?
Noah Kadner
October 24, 2017 at 3:18 amYeah I suggest a screen shot. In FCPX, audio has to be always anchored to something and it cannot be just anchored to time as you would in other track-based NLEs.
Noah
Ty Ford
October 24, 2017 at 11:50 amNoah, et al,
It’s just nuts if you can’t over-ride the magnetic time line. Here I have a PPT converted to a .mov. I imported the narration done separately and now the two are stuck together.
The video has no audio the audio is not imbedded into the video. Both are entirely separate.
To do the project, I need to slice and dice the video and add still frames, clean up the audio and sync it with the video.
Brett Sherman
October 24, 2017 at 12:24 pmThe audio clips all have connection points to the primary (where the video is). See all the short vertical lines? Thus anytime you move the video the audio is going to stay in the same location relative to the video.
I think the simplest way to handle your situation is to move the video out of the primary. Cmd+Opt+Up Arrow. This way both are connected to an empty primary and can be moved independently of each other.
Brett Sherman
One Man Band (If it\’s video related I\’ll do it!)
I work for an institution that probably does not want to be associated with my babblings here.
