Activity › Forums › VEGAS Pro › Sony Vegas Pro 12 doesn’t load video properly
  • Sony Vegas Pro 12 doesn’t load video properly
    Posted by Will Robinson on March 11, 2014 at 3:04 pm
    Hi all!
    My issue is that video simply wont load into SV12. I have videos in mp4, mov and avi formats and none of them work (I need to be able to load all of these). I’ve read that this is down to the codecs *shrug*.
    I can drag mp4 and mov files into the timeline but it loads a green screen. avi files simply aren’t accepted.
    Any help is greatly appreciated, I’ve spent all weekend on this and I’m slowly going insane! I’m new to this so if any replies could be kept as simple as possible then that would be great!
    Ryan Gray replied 9 years, 11 months ago 7 Members · 23 Replies
  • 23 Replies
  • Steve Rhoden
    March 11, 2014 at 3:12 pm
    Something then went wrong with those files.
    Are they on an external drive? and were they working before?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Will Robinson
    March 11, 2014 at 3:19 pm
    Thanks for the quick response!
    the files all work in windows media player and they are held on the same hdd. they also work on other pcs. its just SV12 on my pc thats not loading them correctly.
  • John Rofrano
    March 11, 2014 at 4:47 pm
    Do you have any codec-paks installed like K-Lite? That could have a negative affect.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Will Robinson
    March 11, 2014 at 7:06 pm
    Hi John, thanks for your reply.
    No I haven’t got K-lite.
  • Rick Anvican
    March 11, 2014 at 9:24 pm
    Hi Will,
    Do you know what codecs your mp4, mov and avi files use (e.g. H264, xvid)? MP4, MOV and AVI are containers for video, audio and other data; it is the data that determines if Vegas can import the files. Try importing other supported file formats like MPEG2 and DV AVI to see if they work.
    GPU acceleration could be the culprit for the green screen with MP4s and MOVs, try disabling in Options–>Preferences–>Video (worked for me for some H264 encoded videos). If that doesn’t solve it, conversion may be necessary (e.g. to MJPEG or similar format for editing).
    Is your problem similar to what was discussed in this thread? –> (https://forums.creativecow.net/thread/24/955692)
    I’m relatively new to the forums here but just trying to share what I have learned from the forums, hope it helps,
    RickAVC
  • Stephen Mann
    March 12, 2014 at 12:51 pm
    Since K-Lite was introduced into this thread, do NOT install K-lite codec pack on your editing PC. K-Lite codecs are optimized for game playback and have really crappy encode functions. You risk overwriting the otherwise good codecs installed by Vegas.
    Your video will play on various viewers like VLC and Wondershare because they use their own codecs – not the installed codecs on your PC.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Will Robinson
    March 12, 2014 at 2:23 pm
    Hi Rick, thanks for your reply!
    Yes, I’ve already disabled GPU acceleration, which has sped up the preview window in SV12 a lot! However, how do I determine the codecs of my video files? Is there something I can download to tell me what I need? Also, if I need to install a codec, where would I get it from?
    As I said, I’m completely new to this and don’t want to just guess in case something goes wrong!
    Thanks again for the help!
  • Will Robinson
    March 12, 2014 at 2:26 pm
    Hi Stephen,
    Thanks for letting me know all this, I will definitely keep this in mind!
    Cheers
  • John Rofrano
    March 12, 2014 at 5:31 pm
    [Will Robinson] “However, how do I determine the codecs of my video files? Is there something I can download to tell me what I need? “
    Yes, get either MediaInfo or GSpot (or both). GSpot will also tell you if the codec is installed and let you debug how it’s being processed.
    Then try and get the missing codec from the original creator. So, for example, if you need the DivX codec, get it directly from DivX.com etc.
    ~jr
  • Will Robinson
    March 12, 2014 at 10:46 pm
    Hi John,
    I’ve installed both of those as suggested.
    MediaInfo says I need the AVC codec and takes me to https://www.apple.com/quicktime/download/. I’ve downloaded it and nothing seems to have changed, even after a PC restart. SV12 still shows a green screen for the videos.
    GSpot is showing all the details of the video and says that it is H.264/MPEG-4 AVC but the status is “Codec Status Undetermined”. I’ve installed x264vfw and still no change to the videos.
    I cant help but feel I’m doing something wrong here…
Page 1 of 3
