Ryan Gray
September 21, 2016 at 9:39 amI have this issue where I had a power surge and it rendered some of my files bad. I went through a drive recovery company and they restored nearly everything, but every time I try to open a .veg project file containing all my AVCHD files, once it encounters a bad .mts file it barfs, freezes and crashes. Tried killing off the .sfk files, tried renaming the file, tried opening the veg.bak file, etc.. I tell it to disregard the bad files (upon loading) and no such luck – Vegas (Pro 13) still crashes. Any suggestions?
John Rofrano
September 22, 2016 at 12:45 pmMove the bad files out of the folder they are in so that Vegas Pro can’t find them. That should at least get the project to open.
I would try re-rendering the bad files. Obviously there is still something wrong with their format.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com -
Ryan Gray
September 22, 2016 at 5:32 pmOK I re-rendered them as MP4’s. That still didn’t do the trick. Even when I told Vegas to leave them alone, Vegas DOES open. But after about 2 minutes of being open, even if I just leave it there, I get the following Problem Report and Vegas crashes:
Extra Information
File: C:\Users\XXXXXXXX\AppData\Local\Sony\Vegas Pro\13.0\dx_video_grovel_x64.log
File: C:\Users\XXXXXXXX\AppData\Local\Sony\Vegas Pro\13.0\svfx_video_grovel_x64.log
File: C:\Users\XXXXXXXX\AppData\Local\Sony\Vegas Pro\13.0\ocio_x64.log
File: C:\Users\XXXXXXXX\AppData\Local\Sony\Vegas Pro\13.0\dx_grovel_x64.log
File: C:\Users\XXXXXXXX\AppData\Local\Sony\Vegas Pro\13.0\gpu_video_x64.log
File: E:\CLIENTS\XXXXXXXX\Jasmine & Ted.vegProblem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 453) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\FileIO Plug-Ins\compoundplug\compoundplug.dll
Fault Address: 0x000007FEC72FC929
Fault Offset: 0x00000000000DC929Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 453) 64-bit
Process Description: Vegas Pro
Process Image Date: 2015-06-05 (Fri Jun 05) 23:53:04This is a wedding… project. it’s horrible…I simply can’t edit it. 🙁
I’ve moved compoundplug.dll out of the compoundplug folder but it still doesn’t work…in fact it takes much longer and asks me to verify each of several hundred clips. So I left it in there. I’ve tried it with GPU rendering off and on. I’ve tried increasing Dynamic RAM. I’ve tried that CTRL-W solution or whatever it is. I’ve tried re-encoding them. I’ve tried killing off the .sfk files. I’ve tried renaming the master project file. I’ve tried moving the bad files to a separate location.
Maybe i need to re-encode every single file .mts and use the new files instead?
