Activity › Forums › Apple Final Cut Pro Legacy › Set text aspect in DVCPRO HD 720p timeline
Chandira replied 19 years, 5 months ago 6 Members · 38 Replies
Jeremy Garchow
April 28, 2007 at 1:25 am[JeremyG] “Do me a favor and hit control-q and match the easy setup to your footage.”
Then reselect the title tool and try again.
And still, what kind of drives are you using?
David Eells
April 28, 2007 at 1:26 amI’d be shot if I changed anything (high pressure situation, and as I said, I’m the assistant here), but here are the settings:
Sequence Preset: DVCPRO HD – 720p24
Capture Preset: DVCPRO HD – 720p24 48kz
Device Control Preset: DVCPRO HD FireWire
Playback Output Video: Blackmagic HDTV 720p 59.94Hz – 8 bit (1280 x720)
Playback Output Audio: DeckLink Audio
ETT and PTV same as PlaybackStorage is 2 x 1TB, 1 x 500 GB – both G-TECH drives.
Jeremy Garchow
April 28, 2007 at 1:44 amWell, don’t get yourself killed. It sounds to me like your system resources are full. The reason that the viewer and canvas look different is because the viewer is a different res than your canvas, once you lay in the title, the title conforms to your canvas size.
How much room do you have on your drives and is your capture scratch and render folders pointed to the drive with the most room and speed?
Jeremy
David Eells
April 28, 2007 at 1:51 amThe different size phenomenon is intermittent – it just started up. On the new titles I’m making now, the frame size field is blank. Earlier it was 960×720, but I still had the render problem.
Capture/Render disk has 355 GB available.
Jeremy Garchow
April 28, 2007 at 2:02 am[Budrick21] “The editor who started the project says that when he began the titles worked normally, but then something changed”
This is your problem, man. Really. You have to reset your easy setup. Something changed and you have to change it back, otherwise, render.
David Eells
April 28, 2007 at 2:06 amMaybe so, but the footage and the timeline play perfectly happy together. I’m inclined to think it’s a side-effect of the long timeline.
Jeremy Garchow
April 28, 2007 at 2:09 amThat too, and drives that aren’t exactly the fastest for this kind of long form work.
David Eells
April 28, 2007 at 2:19 amThanks for an enjoyable evening. I’ll make it throouhg this project somehow. See you around the pasture.
Chandira
April 28, 2007 at 6:38 ami have one project in hd.this project is shooted in HD VARAI CAM model is AJ-HDC27FP-1.They tell fcp project seeting for used 1080/23.98psf for HD-SDI INUT use. i want conformation for this setting is correct or not.In my system have fcp 5.1 with black magic 8 bit capture card.that have this settings also there
1080/23.98psf – 8 bit and 10 bit
1080/23.98> 59.94 – 8 bit and 10 bit
also there which one is prefereditor
