Activity Forums Apple Final Cut Pro Legacy Set text aspect in DVCPRO HD 720p timeline
  • Jeremy Garchow
    April 29, 2007 at 4:10 am
    [gary adcock] “if your avid is compatible it will only do it over FW and you have to check the dialog box to capture only the flagged frames.”
    Who’s using an Avid?
  • David Eells
    April 29, 2007 at 2:16 pm
    Hi Gary
    Thanks for wandering into my nightmare. I’m actually working on a Final Cut system serviced by people who only know Avids. It’s a long format piece that was started by another team (in all likelihood using FireWire but we’re not allowed to ask). My tech support is determined to come in through SDI, have never seen a Blackmagic card, but are coming along slowly. So I’m a mechanic repairing a car as it speeds down the highway.
    Fun!
  • Gary Adcock
    April 29, 2007 at 2:43 pm
    https://forums.creativecow.net/readpost/8/934651?
    in this post budrick 21 is talking about”matching an original project and all of the techs are avid guys.”
    It was guessing on my part since there is no mention of the workflow in any posts- but if the original project was done on an avid- it may have been up-converted the footage on capture and created this nightmare. it would not be the first time I have seen this happen.
    this does not appear to be the case here, so bring me up to speed on systems etc. and I am sure between jeremy , walter and I something will happen. The card is not set up correctly – the Fcp easy setup should reset the BMD cards also.
    what do they say in the BMD forum?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • David Eells
    April 29, 2007 at 5:09 pm
    Gary –
    Good idea. I’ve posted in BMD forum and am waiting to hear.
  • Rennie Klymyk
    April 29, 2007 at 7:21 pm
    [Budrick21] “The image appeared to capture normally, had the correct dimensions and aspect, but the subject’s head was cut off slightly, as were the edges – as if the picture had been expanded. When captured, the image sat on the timeline, no render needed. It matched the sequence settings, but there was a loss of information around the edge”
    Just a thought, does your viewing monitor have overscan? With all the people accessing the system someone may have reverted the monitor to their own user set-up. BVM’s have memory cards for different users so they can quickly restore their favorite set-ups for different scenarios. NORM is usually 5% overscan and Underscan is usually 3% under effective screen area but this is user configurable to + or – 15% in the menu for both settings. This could also explain the washed out picture.
  • Gary Adcock
    April 29, 2007 at 7:56 pm
    [Rennie] “Just a thought, does your viewing monitor have overscan? “
    there is no overscan in HD.
    gary adcock
    Studio37
  • David Eells
    April 29, 2007 at 7:59 pm
    No, this could be seen on the canvas and browser. I went so far as to capture a clip once using SDI and once using FireWire to illustrate the phenomenon. It was pronounced.
  • Chandira
    April 30, 2007 at 5:22 am
    thank u i will check out
    editor
Page 4 of 4
