Activity › Forums › Apple Final Cut Pro Legacy › red bar when i add transitions in FCP???
  • Christina Rule
    January 8, 2009 at 2:10 am
    I dont see the AJA Uncompressed 8 bit 720p59.94 in my easy set up?
    http://www.christinarule.com
  • Jeremy Garchow
    January 8, 2009 at 2:23 am
    If you have FCP 6, you need to choose the 59.94 drop down from the frame rate:
  • Christina Rule
    January 8, 2009 at 2:25 am
    wow i feel like such an idiot. Thank you SO much!
  • Jeremy Garchow
    January 8, 2009 at 3:37 am
    You’re welcome.
    Glad you got it sorted.
  • Christina Rule
    January 8, 2009 at 4:10 am
    thanks to everyone!
  • Christina Rule
    January 8, 2009 at 4:22 am
    One last thing… What kind of system would you htink would be able to handle AJA Uncompressed 8 bit 720p59.94
  • David Roth weiss
    January 8, 2009 at 7:12 am
    You need a hefty Raid with eight drives.
    Here’s an excellent resource from CalDigit that will give you the lowdown. https://www.caldigit.com/support/CalDigit-Stream.jpg
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Jeremy Garchow
    January 8, 2009 at 3:43 pm
    When working Uncompressed, you need every ounce of speed and power. David mentioned a very fast array, somewhere in the neighborhood of 300MB/sec and you probably wnat more than that. I use a Sonnet D800RAID and it gets upwards of 350MB.sec when it’s getting kind of full. When it’s empty it’s up near 500. EVen if you get the fastest machine, FCP is not really an Uncompressed workhorse. It just wasn’t designed that way. When working 720p30, you’d get at least rt transitions, and maybe a color corrector 3way, but that’s about it. If you go up to 1080i, you might get a transition.
    My advice would be to get yourself a screaming CPU (a new MacPro) and a decent raid and work in ProResHQ. It’s not uncompressed, but it is compressed 10bit. It is a fantastic codec that holds up very nicely. ProRes requires a MacPro for capture and playback, though. If you don’t want to use a compressed codec, then you can use uncompressed 8bit.
    Jeremy
  • Christina Rule
    January 8, 2009 at 7:37 pm
    Well right now i am working with a pretty fast raid i believe its Fibre Channel.Forgive me if i should like Im lost about this sometimes, I am still learning.
  • Christina Rule
    January 8, 2009 at 7:41 pm
    wouldnt Fibre Channel be fast enough? So the main problem is my computer?
Page 3 of 4
