Activity Forums Adobe Premiere Pro PrPro export to quicktime. HD
  • PrPro export to quicktime. HD
    Posted by Alan Stephens on January 19, 2012 at 10:39 pm
    I need to export from PrPro CS5.5 to a quicktime file (.mov) so I can
    import into a Finalcut 7 project. I’m using the great green screen
    in PRPro, but need to finish a FC project. PrPro or media encoder doesn’t seem to suport quicktime HD.
    I can change the codec to hdv or pro res but it comes out 1620×1080 and has a black border and doesn’t look that sharp either.
    Any one have a clue about this?
    Adobe Tech support is no help at all.
    Alan Stephens
    Chris Tompkins replied 12 years, 4 months ago 6 Members · 19 Replies
  • 19 Replies
  • Ben G unguren
    January 20, 2012 at 5:37 am
    [Alan Stephens] “PrPro or media encoder doesn’t seem to suport quicktime HD.”
    Hi Alan,
    This phrase doesn’t make sense. What do you mean by “quicktime HD”? If you mean quicktime movies that are 1920×1080, they totally support it. I’ve exported hundreds and hundreds of QT HD movies, to a variety of codecs, including ProRes, without problem.
    I was reading your previous post, and it feels like you’re getting frustrated with PPRO and AME and are consequently drawing some hasty conclusions. I teach editing to college kids (mostly FCP) and when they say things like “this just doesn’t support HD”, that’s usually an indicator that something’s gone off-kilter (typically user-error related) and they simply missed it. I’m thinking that there are a few possible problems here:
    1. Your source files are off-kilter. Maybe they are anamorphic but aren’t being interpreted correctly. Or something.
    2. Your timeline is off-kilter. Maybe it isn’t square HD. Maybe your clips aren’t being interpreted correctly inside the timeline — maybe it isn’t being viewed properly, and so you aren’t noticing any of this.
    3. [this is my suspicion] Your export settings are off-kilter. You’re using a preset, and you haven’t gone over all the customizable settings within the preset, or perhaps you don’t know what to look for. Maybe the output is non-square when it should be square, for instance.
    Another possibility is that QT Player’s “info” window isn’t showing the correct data. This is a problem that creeps up with videos exported from lots of programs (including FCP) — it’s supposed to be 1920×1080 but QT tells you it’s something else. And you open it in AE or grab a still for PS, and everything matches up — only QT can’t get things straight.
    Anyways, there are a few rambling possibilities. Don’t discard the Adobe stuff just yet — I’m coming from FCP-land myself, and I find this stuff has a lot to offer.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Chris Tompkins
    January 20, 2012 at 1:16 pm
    From your HD sequence in PPRo – File Export:
    Send to AME for Queue,
    See Pic:
    Choose Quicktime.
    See Pic:
    Choose Prores.
    All there….
    Chris Tompkins
    Video Atlanta LLC
  • Alan Stephens
    January 20, 2012 at 9:36 pm
    I have tried this and here is what I get. Everything lines up except the pixel size doesn’t adjust with the codec. If i adjust it manually I get 1620×1080. when I output I get a black border on the top & bottom. I’ve Never seen this before outside 4×3 & 16×9.
    If I go in and adjust the aspect manually I get squeezed video with a black border.
    Alan Stephens
  • Alan Stephens
    January 20, 2012 at 9:42 pm
    Yes I’m some what frustrated. I started with Premier 5 and when I got to 1.5 pro, I switched to FC about 4 years ago for strategic reasons.
    I really liked Premier, but have gotten used to FC now.
    I would say I’m a novice encoder. I understand that the various
    settings can cause the output to be off-kilter. With todays web end use My clients need more expertise.
    fc as you know has an export form the timeline as I think PrPro once did. I see by design we don’t need it any longer so much.
    Media encoder is fine, but you would think there would be a preset to do this. It is a good way to archive projects in an edited form.
    As for settings I have tried many different settings in order to get things to work. I don’t know about all of the variables so I am shooting in the dark. My source footage is HDV (1440x1080p. I made my sequnce in PrPro new sequence from clip to keep the settings right. no problems in FC or compressor.
    This is a bit like building the airplane as your taking off in it.
    I still have media to deliver.
    Any ideas?
    Alan Stephens
  • Alan Stephens
    January 20, 2012 at 9:45 pm
    screen shot included.
    Alan Stephens
  • Ben G unguren
    January 20, 2012 at 9:54 pm
    In the pixel size for your export settings, unselect the chain-link box just to the right of the numbers (this forces the pixel aspect ratio to remain consistent, but it is set to a 4:3 ratio, and you want 16:9). Then change the 1620 to 1920, and you should be good to go.
    Ben Unguren
  • Alan Stephens
    January 20, 2012 at 11:52 pm
    Thanks, that worked. I thought I tried this before, but maybe not all the settings at the same time.
    Any idea about the vertical jitter issue? I tried Progressive but it was still there on mp4 files at 24fps. when I change it to 29.97 there is no jiggle.
    Alan Stephens
  • Ben G unguren
    January 21, 2012 at 2:58 pm
    Well, your source timeline is 29.97, so it makes sense that a 29.97 export will look better than one at 24. It would work better to export at 29.97, then take it into AE and try to resample the frames into 24fps using Timewarp. It isn’t the best solution, but works tolerably well with some due diligence on google etc. Good luck!
    Ben Unguren
  • Al Bergstein
    January 29, 2012 at 8:45 pm
    Alan, I don’t understand your comment about exporting from the timeline. Pr has an ability to export the sequence, which I think is the same thing you are asking for.
    I would agree that the documentation for Pr (as well as online tutorials that I’ve watched in the last month), leaves a huge amount of opportunity for motivated educators!
    Al
  • Alan Stephens
    January 31, 2012 at 4:26 pm
    I got the answer to my export. I jsut wanted to export the edited sequnece as a quicktime file that could be used in future projects or encoded directly in Media Encoder. I had some problems with aspect ratio in ME
    but got the answer I needed to straighten it out in this thread.
    THX
    Alan Stephens
