Activity › Forums › Adobe Encore DVD › Jumpy mpeg file
Jumpy mpeg file
Posted by Carlos Angeli on June 8, 2010 at 1:34 pmHi. I created a sequence in Premiere CS4, using an imported vob file from a movie trailer.
After changing the extension name to mpg, I was a ble to import it to Premiere. Once I was finished with the editing, I sent it to Encore though the dynamic link.
I can build the dvd just fine. However, the video looks “jumpy” (like frames jumping and overlapping) whenever there´s a fast camera movement or action. It looks fine on more quiet parts or the video.
Any ideas on what might be causing this? The video looks just fine if I play it on its original version.
Dominic Osborne replied 16 years, 3 months ago 4 Members · 13 Replies -
Carlos Angeli
June 8, 2010 at 1:37 pmI forgot to say that I have used this same process with other videos and it worked fine. So I´m guessing it´s something related with this particular kind of video. The original file is DV PAL 25 fps and I´m keeping the same format for the Premiere sequence and for Encore as well.
Jeff Bellune
June 8, 2010 at 1:37 pmYou’ve inverted the field order. Your source footage is likely upper field first, and En defaults to encoding as lower field first.
Create a UFF encoding preset En (use File | Edit Quality Presets) and it should fix the problem.
-Jeff
EDIT: Based on your last post, you may have inverted the field order in Pr, so you’ll have to fix that as well.
The Focal Easy Guide to Adobe Encore DVD 2.0
Carlos Angeli
June 8, 2010 at 2:44 pmThanks for the quick answer Jeff. I´ll try it and post the results later.
How do I check the field order in the video before importing it in Premiere?
Carlos Angeli
June 9, 2010 at 1:00 amWell, I ´ve tried different combinations of changing field order in Premiere and also on Encore as suggested, but still gete the same results.
I would really like to solve this for next the next time
Jeff Bellune
June 9, 2010 at 1:25 am -
Carlos Angeli
June 9, 2010 at 9:07 amI checked the source file with media info as suggested:
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Duration : 7mn 0s
Bit rate mode : Variable
Bit rate : 4 142 Kbps
Nominal bit rate : 6 000 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Bits/(Pixel*Frame) : 0.399
Stream size : 208 MiB (93%)I´m using a DVPAL widescreen lower field first sequence in Premiere. I´m not sure what´s wrong.
Jeff Bellune
June 9, 2010 at 2:42 pmThanks for that info. I was wrong about your source video.
The problem you describe is exactly what happens when the field order of the video is encoded or played back the opposite of the source video’s field order.
I still think it’s getting inverted somewhere along the line. Just to recap: you copied the VOB file(s) directly off of the DVD, and then re-named them to .mpg files for editing, right? You didn’t use any program to process them in any way before importing them into Pr?
-Jeff
Carlos Angeli
June 10, 2010 at 12:39 amYes Jeff. I copied the source file and changed the extension to mpg. I have made one more test following what you told me, and it turned out to play fine in the computer if I play it with media player classic, but still jerky if played with windows media.
I haven´t had the chance to play it on an external dvd player yet. However your advice has helped me to understand the field order concept.
Paul Benson
June 17, 2010 at 1:37 amIt has been awhile since I tried importing a vob by renaming it to mpg. I usually saw what you are describing. I think it had something to do with the audio being muxed in the vob file. I typically used a vob to avi converter and that made things work properly.
Pauley
Carlos Angeli
June 17, 2010 at 9:31 amPaul,
could you recommend any converter software? Were you able to keep the quality of the video?
