Activity › Forums › Adobe Encore DVD › Jumpy mpeg file
Paul Benson
June 17, 2010 at 3:50 pm -
Carlos Angeli
June 17, 2010 at 10:11 pmI´ll give it a shot with some footage I need to prepare for next week. I´ll let you know how it goes.
Thanks a lot for the feedback
Dominic Osborne
June 18, 2010 at 3:01 pmCheck what your Premiere project is set to be, in terms of field order. That’s under the Project menu. When you find the info, it’ll be greyed out but it should still tell you.
It may be that your project is upper field first.
Also seems something may be awry as you said you’re doing 16:9 yet the clip you’ve reported info of is suggesting it’s 4:3.
Anyway, if the Premiere project is upper field first, then right-click the clip in your timeline, go to field options, and check the ‘reverse / inverse field order’ checkbox, and that will likely help.
Dominic Osborne
Director & Head of Visuals
Eight Eyed Sea Bass Ltd
http://www.eesb.tv
