Activity › Forums › Creative Community Conversations › It’s Alive!
It’s Alive!
Posted by David Mathis on July 27, 2015 at 8:07 amYou heard right, the wait is over. The new version of Resolve is here, in beta form! Going to install Tuesaday, still nothing new on Fusion, hopefully soon.
The magnetic timeline, it’s magnetic-o-matic!
David Mathis replied 11 years, 1 month ago 10 Members · 17 Replies -
Gabe Strong
July 27, 2015 at 8:17 amHa, I so beat you to the post….by a little over one minute….
Already playing with it….so far I like!!!!Gabe Strong
G-Force Productions
http://www.gforcevideo.com -
Scott Witthaus
July 27, 2015 at 11:11 amDoes it actually play back material without dropping frames? R11 was such a dud that I have stopped looking at Resolve as an edit solution, only a color corrector when absolutely needed.
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU Brandcenter -
Craig Shields
July 27, 2015 at 1:26 pmI know it’s beta but it still doesn’t seem too responsive on a new Macbook Pro.
Steve Connor
July 27, 2015 at 2:34 pmOn my systems it’s much faster, but still not fast enough. However I imagine that it will work well on a higher spec system
Andrew Kimery
July 27, 2015 at 4:08 pmAnyone tried syncing multiple cameras by waveform? I asked about it at NAB and a BM rep said that function was still pretty raw so they weren’t demoing it on the show floor. Hopefully it’s made a lot of headway since then.
Morten
July 27, 2015 at 6:52 pmI’m running a 2.5 Ghz i7 MBP with 16Gb RAM, and responsiveness seems OK.
If I apply heavy grading and go back to editing, it does drop frames, but that could be expected.
So far like what I see…– No Parking Production –
Adobe CC2014, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8
Gabe Strong
July 27, 2015 at 6:59 pmFrom what I can tell, it is highly dependent of the GPU, so it really
depends what card you have as far as good real time playback.
I have been searching through the ‘DaVinci Configuration guide’
in search of approved cards, and can only find 10 listed ‘approved’ GPU’s.
It also says that ‘minimum’ GPU RAM for HD is 2 GB, ‘approved’ is 3 GB
and ‘minimum’ GPU RAM for UHD/4K is 4 GB and ‘approved’ is 8 GB.
So in theory if you have a card that meets those specs you are good…..Gabe Strong
G-Force Productions
Craig Shields
July 27, 2015 at 7:36 pmReally, your fans don’t crank up? What about when you scrub the timeline? Also, do you have any issue with audio when importing different codecs like mxf?
Morten
July 27, 2015 at 8:22 pmAfter layering a couple of more effects and doing some speed changes I get some fan activity.
Hopefully the main release will be a little more optimised – but this is a lot better than v11.– No Parking Production –
Craig Shields
July 27, 2015 at 8:50 pmGuess I’ll have to wait another year for 13. It’s a pity because its such a beautiful UI. But I need my scrub and JKL to be fast and responsive.
