Activity › Forums › Apple Final Cut Pro Legacy › How to insert img file in native resolution without stretching
  • How to insert img file in native resolution without stretching
    Posted by Ohki Komoto on May 6, 2009 at 1:46 pm
    Hey COW surfers
    I’m usually a Sony Vegas editor, but recently I acquired a job where FCP would be more convenient as they already have a editing set up in the company offices where instant feedback would be well a few footsteps away. (and the catered lunches don’t hurt either, other than my scale)
    It is a simple seminar type of video series I’m putting together and i’m using the DVDPRO HD 720p60 setting where as you know puts it in the 960×720 pixel ratio but comes out as 1280×720. The problem lies in that I want to put powerpoint slides as images in as it goes hand in hand with the project, but when I stick these images in, they are stretched automatically. I have the PPT slides as 4:3 aspect ratio when I export which is fine, since I’ll have a full 1280 x720 background image underneath to composite a seamless slide which looks undistorted but fills the screen.
    Is there a way I can tell FCP not to stretch my slides pics?
    Ohki
    Ohki Komoto replied 17 years, 4 months ago 4 Members · 12 Replies
  • 12 Replies
  • David Battistella
    May 6, 2009 at 3:43 pm
    My guess is that the stretch is only happening in the viewer window. If you drag the file into the timeline it should fit in the correct aspect ratio for the sequence you have selected.
    You can also select the clip in the timeline and right click to select REMOVE ATTRIBUTES and remove the ones the may have been selected automatically.
    Hope this helps.
    David
    Peace and Love 🙂
    Read my Blog
    https://blogs.creativecow.net/DavidBattistella
  • Ohki Komoto
    May 6, 2009 at 4:16 pm
    Thank you David for the feedback.
    Well, that is what I usually do, I just drag straight into the timeline and it is stretched. In the viewer, or whatever, when i double click on it in the imported files folder, it looks fine. I tried the remove attributes option before my other post, but did not see anything pertaining to the way it was stretched. nothing was highlighted.
    Guess I’ll try some other measurements in Power point to export.
    Ohki
  • David Battistella
    May 6, 2009 at 5:14 pm
    Yes,
    Double check to see how the files open in Photoshop. You might be applying the stretch on export.
    David
    Peace and Love 🙂
    Read my Blog
  • Ohki Komoto
    May 6, 2009 at 7:04 pm
    No, I’m exporting as 4:3 in powerpoint.
    I double checked in photoshop with the ppt slide, and the bigger background and it’s fine before FCP. I just need to tell FCP not to stretch my image however that is done. It is probably something very simple to do, but sometimes that isn’t intuitive to a new user.
  • Rafael Amador
    May 7, 2009 at 8:46 am
    Hi Ohki,
    Make sure that FC is interpreting properly the kind of pixels of the PPP.
    You have exported 4×3 and FC may be reading as Square.
    rafael
    http://www.nagavideo.com
  • Ohki Komoto
    May 7, 2009 at 1:14 pm
    Rafael, i’m not quite sure how to tell fcp to interpret individual assets differently in that aspect.
    The ppt exports the 4:3 slide images as 960×720 which FCP will always automatically bump up to stretch to fit the 1280×720, if you are using the DVCPRO HD 720p60fps. I tried testing a 961×721 resolution of the same image edited in PS, and it comes in natively. I knew that footage would get stretched in that format, since it is the way that it packs that data, but guess it effects any stills of the 960×720 reso as well. So, just export the settings of the slides tweaked ever so slightly is the solution i’m going to go with for now, unless someone can suggest a cleaner solution. Which would help, since the graphs/etc on the slides are looking a little fuzzy in this process.
    Thanks for replying guys.
    Sincerely
    Ohki
  • Dennis Leppell
    May 7, 2009 at 2:51 pm
    Go to user preferences—->editing tab.
    on the lower right corner of the window is a check box next to “Always scale clips to sequence size”. Uncheck this. Test and report back
  • Ohki Komoto
    May 7, 2009 at 3:11 pm
    Dennis
    I tried it on an existing sequence and a new one. It sounded promising but it still manages to stretch my image :/
    Ohki
  • Rafael Amador
    May 7, 2009 at 3:49 pm
    Hi Ohki,
    960×720 is perfectly 4×3 when built with Square pixels.
    Look in the Browser, pixels aspect column, and make sure that the Pixels are Square.
    Rafael
  • Rafael Amador
    May 7, 2009 at 4:13 pm
    No Ohki.
    You don’t have to change nothing in your sequence setting.
    What you have to look for is in the Browser window.
    Double click the PPP in the Browser and scroll until the “Pixels Aspect” column.
    Make sure that is SQUARED.
    If you have exported the PPP 960×720, 4×3, necessarily the pixels must be Square.
    FC may be interpreting the pixels as a different kind, so when you drag the clip to the sequence they get distorted.
    rafael
