Activity › Forums › Apple Final Cut Pro Legacy › How to insert img file in native resolution without stretching
Ohki Komoto replied 17 years, 4 months ago 4 Members · 12 Replies
Ohki Komoto
May 7, 2009 at 4:13 pmHey Rafael, thanks
I know what you mean, by changing the aspect ratio to square in the sequence settings. But the footage I’m using needs to use the DVCPRO HD720p60 setting to be displayed correctly.
Regardless
I tried changing it to square, but it squishes my footage, then I check anamorphic and it looked fine, it was just like the DVCPROHD720 setting , but bah….my image is still stretched. I think i’m going to just accept the distorted look (until a solution presents itself), it is still more than readable, it is just not ideal.Thanks
Ohki -
Ohki Komoto
May 7, 2009 at 5:10 pmAhhh!
Gotcha, and yep, it was something very simple 🙂
Thank you so much! I should’ve looked in the browser for all the other settings I can configure.
Thanks COW surfers, and Rafael!
Now my project should look a bit more professional.
Appreciatively
Ohki
