Activity Forums Apple Final Cut Pro Legacy First HDV Project
  • First HDV Project
    Posted by Nicholas Bierzonski on June 15, 2006 at 1:22 pm
    Hi, I’m new to HDV. I was given footage shot on a Sony HVR-Z1U/Z1N it was shot on 1080i 60i. What should I capture this as and what should I set my timeline to so it can play back in real time? I’ve found some settings that are close but not quite what I need. I work on at G5 with a HD screen and I have a Kona 2 setup. Any ideas would be of great help. Thanks!
    -Nicholas Bierzonski
    Editor/DVD Author/Java Boy
    http://www.finalfocusvideo.com
    Walter Biscardi replied 20 years, 3 months ago 7 Members · 14 Replies
  • 14 Replies
  • Steve Eisen
    June 15, 2006 at 1:36 pm
    If I were editing HDV, I would capture as DVCPro HD.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Ramendemon
    June 15, 2006 at 1:58 pm
    I agree, if you you can capture it through your card as DVCProHD, it will probably save you a lot of time. For some reason HDV takes longer to render, export, and encode to MPEG2.
  • Mark Maness
    June 15, 2006 at 2:58 pm
    Well, that’s because HDV is a transport stream – not an edit stream. The computer has to decode and re-encode each and every single frame… That’s really processor intensive.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Nicholas Bierzonski
    June 15, 2006 at 3:33 pm
    I thought it was possible to play HDV back in real time on a G5. What I want to do is capture HDV let it remain native so I can view it in realtime. Then I want to add timecode reader and play this play in realtime to VHS. Is that possible or do I have to render. I’ve tried matching my sequence as closely as possible to the camera manuals specs but I havn’t had any luck. What is the best way you would recommend capturing and outputting a real time window burn?
  • Jeff Carpenter
    June 15, 2006 at 4:27 pm
    What are you trying to match? You should just use the Easy Setup and pick the HDV format. Then start a new project.
    What version of Final Cut do you have? You need at least 5.0
  • Mark Maness
    June 15, 2006 at 5:03 pm
    In order to do this in realtime, you’ll need a capture card like the AJA Kona series tp view output to a source. But when add any filters to a HDV clip, you’ll have to render it.
    Wayne Carey
    Schazam Productions
  • Steve Eisen
    June 15, 2006 at 5:23 pm
    Connect your camera/deck to VHS deck. Your camera/deck should be able to display timecode to your VHS deck.
    Steve Eisen
    Director-At-Large
    June 15, 2006 at 5:48 pm
    The easy setup for HDV did the trick. I can play HDV back in realtime and I can see it on my HD monitor correctly. I set my Kona card to output 1920x1080i 30p which works for the audio but I can’t see any video. What setting should I set my Kona card to so I can output video and audio?
  • Mark Maness
    June 15, 2006 at 6:25 pm
    Make sure that in the Kona Control Panel under Format that your Primary (Native) Format is set to 1080i29.97 and your Analog Out is set to the same.
    Wayne Carey
    Schazam Productions
    June 15, 2006 at 7:09 pm
    Thanks! I’ll try that and see how it works after I finish capturing this tape.
