Activity Forums Boris FX Final Cut Pro crash due to use of BCC 6 plugin
  • Final Cut Pro crash due to use of BCC 6 plugin
    Posted by Logan Grey on November 1, 2009 at 9:14 am
    Final Cut Pro quit unexpectedly while using the BCC NRTAll plugin.
    Any thoughts as to why I keep experiencing intermittent crashes? I also seem to have the same kind of issue when using Noise Industries’ FXFactory Pro plugins. Is it by chance something on my side I could fix?
    Process: Final Cut Pro [972]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 7.0.1 (7.0.1)
    Build Info: FCPApp-910141802~4
    Code Type: X86 (Native)
    Parent Process: launchd [107]
    PlugIn Path: /Library/Plug-Ins/FxPlug/BCC NRTAll.fxplug/Contents/MacOS/BCC NRTAll
    PlugIn Identifier: com.BorisFX.BCC NRTAll
    PlugIn Version: 6 . 0 . 4, 8 bit (341)
    Date/Time: 2009-11-01 01:10:39.975 -0800
    OS Version: Mac OS X 10.6.1 (10B504)
    Report Version: 6
    Interval Since Last Report: 2638232 sec
    Crashes Since Last Report: 45
    Per-App Interval Since Last Report: 205765 sec
    Per-App Crashes Since Last Report: 19
    Anonymous UUID: DEB39ADD-EF1F-4837-AE4D-63C29C39EAFC
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000009
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Application Specific Information:
    objc_msgSend() selector name: retain
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    0 libobjc.A.dylib 0x90c9592c objc_msgSend + 44
    1 com.apple.Foundation 0x91abd88e NSKeyValuePushPendingNotificationPerThread + 81
    2 com.apple.Foundation 0x91abd224 NSKeyValueWillChange + 497
    3 com.apple.Foundation 0x91aa250b
    (And the next four pages of meaningless gibberish that was posted, which means nothing to anyone other than the Apple engineers (who don’t come here and read this stuff), has been removed by the site administrators. PLEASE DO NOT post these incredibly long and useless piles of text, we would appreciate it.)
    Matt Mullen replied 16 years, 4 months ago 7 Members · 26 Replies
  • 26 Replies
  • Matt Mullen
    November 3, 2009 at 2:35 pm
    Logan,
    Are you getting these crashes consistently?
    Could you send the full crash report in a text file to support@borisfx.com Subject Attn: Matt with steps on how to reproduce the crash?
    -Matt
  • Logan Grey
    November 3, 2009 at 4:05 pm
    I apologize for adding that extra text at the bottom.
    It doesn’t happen all the time. The best I can describe it is it happens every so often. Maybe once every 10 minutes depending on my use of the plugins.
    I’ll email that ASAP per your instructions. Thanks again!
  • Matt Mullen
    November 3, 2009 at 5:20 pm
    I’ll look for it.
  • Matt Mullen
    November 5, 2009 at 4:01 pm
    Logan,
    Did you ever send that info?
  • Logan Grey
    November 5, 2009 at 5:20 pm
    I was using some of the BCC plugins yesterday to try and get some of that code again, but thankfully I haven’t experienced any crashes yet. Sorry for that delay. I’ll send it to you the next time I get a crash error message. Thanks again!
  • Matt Mullen
    November 5, 2009 at 6:47 pm
    Sounds good.
  • Logan Grey
    November 12, 2009 at 6:36 am
    I sent the email out. Thanks again!
  • Kenny Powerass
    November 20, 2009 at 1:13 am
    Any resolution to this?
    I just upgraded to Snow Leopard, the latest FCP AND the latest BCC. I’ve been getting the same error message.
    Thanks.
  • Matt Mullen
    November 20, 2009 at 3:01 pm
    Kenny,
    There is no resolution to this at the moment. It is something that is being monitored and worked on. As soon as there is a fix you can expect me, or someone else, to post it here.
    -Matt
  • Kuhnen Brown
    November 30, 2009 at 9:13 am
    FCP 7 crashes consistantly with this error when I apply BCC Extruded Text filter to a slug. Crash occurs when I either render the timeline or export to self contained QT movie.
    FCP 7, Snow Leopard, BCC 6.0.4, NVidea GX 285, Mac Pro early 2009
    Kuhnen
Page 1 of 3
