Final Cut Pro crash due to use of BCC 6 plugin
Matt Mullen replied 16 years, 4 months ago 7 Members · 26 Replies
Dan Luke
December 3, 2009 at 8:42 pmI’m also having crashes with the Boris continuum plug-in & FCS3. I have used the uprez filter in a couple of spots, applied to the brick generator and maybe the scan line filter.
Process: Final Cut Pro [2985]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.1 (7.0.1)
Build Info: FCPApp-910141802~4
Code Type: X86 (Native)
Parent Process: launchd [105]PlugIn Path: /Library/Plug-Ins/FxPlug/BCC NRTAll.fxplug/Contents/MacOS/BCC NRTAll
PlugIn Identifier: com.BorisFX.BCC NRTAll
PlugIn Version: 6 . 0 . 5, 8 bit (411)Date/Time: 2009-12-03 14:30:47.219 -0600
OS Version: Mac OS X 10.6.2 (10C540)
Report Version: 6Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000020
Crashed Thread: 0 Dispatch queue: com.apple.main-threadApplication Specific Information:
objc_msgSend() selector name: retainThread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x91546ed7 objc_msgSend + 23
1 com.apple.Foundation 0x954a5802 NSKeyValuePushPendingNotificationPerThread + 81
2 com.apple.Foundation 0x954a5198 NSKeyValueWillChange + 497
3 com.apple.Foundation 0x9548a47f -[NSObject(NSKeyValueObserverNotification) willChangeValueForKey:] + 211
4 com.apple.CoreFoundation 0x92295487 CFDictionarySetValue + 183
5 com.apple.Foundation 0x9548087a -[NSCFDictionary setObject:forKey:] + 308
6 com.apple.ProFX 0x00f02070 -[QCPatch(ProFXInputGrouping) pfxSetGroupDisabled:disabled:] + 330
7 …uartzComposer.FxPlugWrapper 0x0e69cfa1 0xe694000 + 36769
8 com.BorisFX.BCC NRTAll 0x23967b97 -[BCCNRTFxPlugFilter SetHideState:HiddenByAEfilter:SetAPI:ParmsAPI:atTime:aeFilter:] + 215
9 com.BorisFX.BCC NRTAll 0x23968023 -[BCCNRTFxPlugFilter UpdateContextualControls] + 723
10 com.BorisFX.BCC NRTAll 0x23969762 -[BCCNRTFxPlugFilter parameterChanged:] + 674 -
Dan Luke
December 3, 2009 at 8:53 pmI can get boris to crash FCS 3 consistently. I am making assemble edits to tape. Each tape is a copy of the same timeline. I finish a tape and replace it with a fresh tape and try to drag the timeline to the assemble icon and FC crashes telling me that Boris NRTAII was the likely cause.
Michael Tate jones
March 10, 2010 at 6:20 pmI have the same issue as well, however, I’m still using BCC5 with FCP Studio 3. This is discouraging as I was hoping the eventual upgrade to BCC 6 would solve the problem.
Michael Tate jones
March 15, 2010 at 8:23 pmHi Matt, it’s been a few months since the original post on this issue. Any updates for us? Would REALLY appreciate getting this bug squashed ASAP 🙂
Michael Tate jones
March 15, 2010 at 8:24 pmHere’s my crash code if it helps…
Parent Process: launchd [102]PlugIn Path: /Library/Plug-Ins/FxPlug/BCC NRTAll.fxplug/Contents/MacOS/BCC NRTAll
PlugIn Version: 5 . 0 . 5, 8 bit (76)Date/Time: 2010-03-15 15:12:36.493 -0500
Report Version: 6Interval Since Last Report: 187339 sec
Crashes Since Last Report: 6
Per-App Interval Since Last Report: 139726 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: 815A6A6B-1305-4397-AAA0-40197853791DException Type: EXC_BAD_ACCESS (SIGBUS)
Crashed Thread: 0 Dispatch queue: com.apple.main-thread -
Neil Weaver
March 17, 2010 at 10:49 amI would like to add my voice to the calls for an urgent fix of this issue. Most frustrating.
Matt Mullen
March 24, 2010 at 11:19 pmHey Guys,
Just want to let you know FCP 7.0.2 has been released. This update should resolve your issues.
Michael Tate jones
March 25, 2010 at 2:50 pmGreat! Just installed it. I’ll let you know how it goes. Hopefully that NRTAll bug is squashed.
Matt Mullen
April 22, 2010 at 2:49 pmAny word Michael?
I also want to let you know we identified a similar crashing problem running 2 graphics cards in a machine.
If your crashing problems aren’t resolved this is something to look at.
