Final Cut Pro crash due to use of BCC 6 plugin
Matt Mullen replied 16 years, 4 months ago 7 Members · 26 Replies
Michael Tate jones
April 22, 2010 at 3:16 pmI’m still seeing that bug pop up either during a render or occasionally when the CTI is over a clip with a Boris effect.
Don’t have 2 video cards, but we do have a Black Magic card in the machine which technically may be considered a second video source I guess.
Just yesterday I was trying to render a clip with the 3D extruded shatter effect and it would crash with that same NRTAll bug. Strangely enough it would render ok if my frame size was 1280×1080 30P with a pixel aspect ratio of HD 1280×1080. But if I switched to 1920×1080 60i with a square aspect ratio it would crash during the render.
Hope this helps.
Matt Mullen
April 22, 2010 at 3:26 pmOk,
Just to double check.
Are you running FCP 7.0.2 and the latest BCC update 6.0.7.1?
Michael Tate jones
April 22, 2010 at 4:12 pmYes, running FCP 7.02, but I haven’t upgraded to BCC 6 yet. Still running the latest version of BCC 5.
Matt Mullen
April 22, 2010 at 4:14 pmThis is most likely contributing to your problem.
Could you possibly test with the trial of BCC 6 and see if your problem is resolved?
The 6.0.7.1 release was to specifically address this issue.
Michael Tate jones
April 22, 2010 at 4:17 pmI’ll give it a try. Will I be able to easily revert back to my licensed copy of BCC 5?
Matt Mullen
April 22, 2010 at 4:20 pmBCC 6 will replace the BCC 5 files but the licensing will stay intact.
You can simply reinstall BCC 5 or back up the BCC 5 plugin files from Mac HD> Library> Plug-ins> FxPlug folder.
