Activity › Forums › Maxon Cinema 4D › Cinema 4D (R19) won’t launch on my Mac
  • Owen Rucker
    October 23, 2019 at 2:53 pm
    So I found this thread after I deleted my C4D applications but now none of my installers will open. Do we think this fix will allow me to run R18-20 installers?
  • Ian Davies
    December 2, 2019 at 9:25 pm
    Came across this thread the other day when the exact same thing started happening to me. Differences to my circumstance seem to be:
  • Problem occurred after running the 10.14.6 combo updater, not iTunes update
  • No warnings about MobileDevice.framework in Console. Is that where it would show up?
  • Replacing MobileDevice.framework with the “good” version as kindly posted by Xavier did not resolve the issue.
  • Can anyone offer any other suggestions? It seems bizarre to me that Maxon aren’t dealing with this beyond simply “noting” it on their support site with a link to this thread! What on earth is Cinema4D doing relying on a private framework related to mobile device support…??
    Any help troubleshooting would be gratefully received. Fortunately I just finished a big 3D job the day before this happened, and I haven’t got any other jobs requiring it at the moment, but as soon as one comes in I’m going to be in a fix.
  • Xavier Bonet
    December 2, 2019 at 10:00 pm
    Hi, Ian,
    I’m sorry to hear you’re having this issue; as sorry as I am to hear this issue is still a thing and that all Maxon are doing to solve it is linking back to this post… I too wondered why they would rely on a private framework, let alone one that has to do with mobile device support.
    Anyway, as for your first question: Indeed, I got the error in Console, at the very end of the startup attempt:
    WARNING: Could not load dll. Error code: dlopen(/Applications/MAXON/Cinema 4D R19/corelibs/c4dplugin.xlib, 6): Symbol not found: _xpc_file_transfer_create_with_path
    Referenced from: /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
    Expected in: /usr/lib/libSystem.B.dylib
    in /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice. (file:///Applications/MAXON/Cinema 4D R19/corelibs/c4dplugin.xlib) [osx_dll.cpp(89)] [general.cpp(266)]
    The fact that you’re not getting this, that swapping the framework file hasn’t worked for you, and that your issue started after you updated elsewhere makes me think that perhaps your issue isn’t related to the MobileDevice.framework.
    Do you get any warnings at all in the Console? Look for the word “error”. What do you get just before the the startup process exits?
    If you haven’t already, maybe the following are worth a try:
  • Deleting the contents of your Cache, Launch Agents, Saved Application State, Launch Daemons, etc., folders
  • Reset the System Management Controller *
  • Reset the NVRAM *
  • Launch in Recovery Mode and run First Aid on your drives
  • Delete the Mesa folder located in Applications/MAXON/Cinema 4D R19/resources/libs/osx/ **
  • In my first post I noted them as not having worked for me, but maybe they’ll work for you.
    * If you don’t know how to do this, I’ll be glad to post instructions. ** I found this recommendation online somewhere, though I can’t remember where. I recommend you make a copy of the Mesa folder before you delete it, just in case.
    Anyway, hope some of this may help you out! Good luck!
    ________________________________________
    …So this is how I managed to bungle it up today.
  • Ian Davies
    December 6, 2019 at 10:53 am
    Hi Xavier,
    Thanks for taking the time to respond and I apologise for my slow reply.
    I’ve tried all those steps without success, although on the ‘delete folders’ step I wasn’t sure what the ‘etc’ might also refer to! I used Onyx to rebuild things like LaunchServices, dyld shared cache, XPC cache, application saved states.
    There’s nothing in the console that contains ‘error’ during the abortive Cinema4D launches. Even just filtering on messages containing ‘cinema’ or ‘Maxon’ don’t seem to produce anything of note, other than regular logging of app launch, app closure, saved state and so on.
    I can post the crash report if you think that will help?
  • Xavier Bonet
    December 6, 2019 at 12:18 pm
    Hi Ian!
    Sorry about the equivocal “etc.”—probably wrote it late at night and tired of the fight with this issue! ???? I meant all other folder you can think of that holds temp files. It seems like you’ve done a pretty complete housecleaning in that sense… so I think I would safely say that your issue has nothing to do with the same issue we’ve had.
    I think it would be good a idea to post the crash report. I’ll surely look over it to see if I can find anything weird, but I myself are very much stumbling in the dark in that area, so perhaps I won’t be of much help—but someone else in the forum might be!
    Have a great day! And I hope you manage to resolve this soon!
  • Ian Davies
    December 6, 2019 at 12:24 pm
    Here you go.
    Process: CINEMA 4D [74810]
    Path: /Applications/MAXON/*/CINEMA 4D.app/Contents/MacOS/CINEMA 4D
    Identifier: net.maxon.cinema4d
    Version: 19.1 (19.1)
    Code Type: X86-64 (Native)
    Parent Process: ??? [1]
    Responsible: CINEMA 4D [74810]
    User ID: 501
    Date/Time: 2019-12-06 09:23:27.819 +0000
    OS Version: Mac OS X 10.14.6 (18G1012)
    Report Version: 12
    Anonymous UUID: 3CF71565-91DE-6993-29A1-C0C50954128C
    Time Awake Since Boot: 260000 seconds
    System Integrity Protection: disabled
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x00007ffeed821f38
    Exception Note: EXC_CORPSE_NOTIFY
    Termination Signal: Segmentation fault: 11
    Termination Reason: Namespace SIGNAL, Code 0xb
    Terminating Process: exc handler [74810]
    VM Regions Near 0x7ffeed821f38:
    MALLOC_MEDIUM 00007fed97800000-00007fed98000000 [ 8192K] rw-/rwx SM=PRV
    –> STACK GUARD 00007ffeea022000-00007ffeed822000 [ 56.0M] —/rwx SM=NUL stack guard for thread 0
    Stack 00007ffeed822000-00007ffeee022000 [ 8192K] rw-/rwx SM=SHM thread 0
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0 c4dplugin.xlib 0x000000010752af34 0x106729000 + 14688052
    1 net.maxon.cinema4d 0x0000000101d3b50e 0x101bde000 + 1430798
    2 net.maxon.cinema4d 0x0000000101d3b11e 0x101bde000 + 1429790
    3 c4dplugin.xlib 0x00000001073949e2 0x106729000 + 13023714
    4 Farm18.dylib 0x000000011ac1092c 0x11abc9000 + 293164
    5 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    6 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    7 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    8 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    9 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    10 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    11 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    12 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    13 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    14 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    15 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    16 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    17 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    18 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    19 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    20 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    21 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    22 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    23 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    24 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    25 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    26 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    27 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    28 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    29 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    30 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    31 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    32 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    33 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    34 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    35 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    36 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    37 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    38 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    39 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    40 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    41 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    42 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    43 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    44 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    45 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    46 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    47 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    48 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    49 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    50 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    51 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    52 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    53 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    54 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    55 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    56 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    57 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    58 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    59 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    60 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    61 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    62 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    63 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    64 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    65 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    66 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    67 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    68 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    69 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    70 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    71 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    72 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    73 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    74 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    75 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    76 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    77 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    78 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    79 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    80 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    81 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    82 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    83 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    84 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    85 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    86 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    87 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    88 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    89 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    90 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    91 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    92 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    93 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    94 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    95 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    96 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    97 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    98 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    99 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    100 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    101 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    102 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    103 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    104 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    105 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    106 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    107 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    108 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    109 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    110 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    111 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    112 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    113 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    114 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    115 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    116 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    117 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    118 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    119 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    120 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    121 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    122 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    123 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    124 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    125 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    126 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    127 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    128 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    129 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    130 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    131 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    132 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    133 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    134 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    135 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    136 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    137 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    138 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    139 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    140 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    141 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    142 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    143 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    144 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    145 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    146 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    147 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    148 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    149 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    150 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    151 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    152 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    153 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    154 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    155 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    156 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    157 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    158 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    159 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    160 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    161 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    162 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    163 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    164 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    165 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    166 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    167 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    168 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    169 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    170 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    171 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    172 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    173 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    174 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    175 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    176 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    177 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    178 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    179 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    180 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    181 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    182 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    183 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    184 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    185 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    186 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    187 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    188 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    189 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    190 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    191 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    192 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    193 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    194 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    195 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    196 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    197 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    198 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    199 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    200 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    201 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    202 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    203 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    204 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    205 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    206 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    207 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    208 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    209 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    210 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    211 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    212 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    213 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    214 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    215 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    216 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    217 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    218 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    219 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    220 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    221 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    222 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    223 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    224 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    225 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    226 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    227 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    228 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    229 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    230 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    231 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    232 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    233 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    234 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    235 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    236 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    237 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    238 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    239 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    240 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    241 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    242 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    243 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    244 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    245 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    246 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    247 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    248 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    249 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    250 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    251 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    252 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    253 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    254 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    255 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    256 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    257 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    258 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    259 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    260 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    261 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    262 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    263 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    264 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    265 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    266 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    267 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    268 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    269 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    270 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    271 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    272 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    273 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    274 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    275 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    276 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    277 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    278 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    279 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    280 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    281 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    282 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    283 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    284 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    285 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    286 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    287 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    288 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    289 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    290 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    291 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    292 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    293 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    294 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    295 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    296 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    297 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    298 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    299 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    300 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    301 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    302 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    303 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    304 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    305 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    306 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    307 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    308 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    309 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    310 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    311 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    312 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    313 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    314 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    315 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    316 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    317 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    318 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    319 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    320 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    321 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    322 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    323 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    324 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    325 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    326 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    327 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    328 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    329 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    330 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    331 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    332 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    333 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    334 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    335 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    336 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    337 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    338 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    339 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    340 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    341 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    342 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    343 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    344 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    345 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    346 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    347 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    348 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    349 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    350 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    351 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    352 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    353 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    354 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    355 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    356 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    357 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    358 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    359 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    360 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    361 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    362 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    363 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    364 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    365 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    366 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    367 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    368 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    369 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    370 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    371 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    372 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    373 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    374 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    375 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    376 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    377 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    378 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    379 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    380 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    381 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    382 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    383 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    384 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    385 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    386 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    387 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    388 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    389 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    390 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    391 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    392 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    393 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    394 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    395 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    396 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    397 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    398 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    399 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    400 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    401 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    402 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    403 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    404 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    405 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    406 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    407 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    408 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    409 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    410 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    411 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    412 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    413 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    414 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    415 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    416 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    417 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    418 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    419 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    420 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    421 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    422 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    423 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    424 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    425 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    426 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    427 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    428 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    429 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    430 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    431 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    432 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    433 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    434 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    435 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    436 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    437 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    438 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    439 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    440 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    441 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    442 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    443 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    444 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    445 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    446 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    447 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    448 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    449 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    450 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    451 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    452 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    453 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    454 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    455 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    456 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    457 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    458 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    459 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    460 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    461 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    462 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    463 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    464 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    465 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    466 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    467 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    468 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    469 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    470 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    471 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    472 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    473 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    474 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    475 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    476 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    477 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    478 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    479 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    480 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    481 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    482 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    483 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    484 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    485 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    486 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    487 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    488 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    489 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    490 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    491 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    492 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    493 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    494 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    495 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    496 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    497 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    498 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    499 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    500 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    501 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    502 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    503 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    504 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    505 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    506 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    507 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    508 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    509 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    510 Farm18.dylib 0x000000011ac110c4 0x11abc9000 + 295108
    511 Farm12.dylib 0x000000011aad0c80 GePrintCapturer(String const&) + 64
    Thread 1:
    0 libsystem_pthread.dylib 0x00007fff790f53f0 start_wqthread + 0
    Thread 2:: CoreTimerThread
    0 libsystem_kernel.dylib 0x00007fff7903f0a6 kevent64 + 10
    1 net.maxon.cinema4d 0x0000000101cf0e00 0x101bde000 + 1125888
    2 libsystem_pthread.dylib 0x00007fff790f62eb _pthread_body + 126
    3 libsystem_pthread.dylib 0x00007fff790f9249 _pthread_start + 66
    4 libsystem_pthread.dylib 0x00007fff790f540d thread_start + 13
    Thread 3:: Crash Handler
    0 libsystem_pthread.dylib 0x00007fff790f668f _pthread_tsd_cleanup + 523
    1 libsystem_pthread.dylib 0x00007fff790f9655 _pthread_exit + 70
    2 libsystem_pthread.dylib 0x00007fff790f62f6 _pthread_body + 137
    Thread 4:
    Thread 5:: Dispatch queue: com.apple.root.default-qos.overcommit
    0 libxpc.dylib 0x00007fff7913055d _xpc_serializer_pack + 373
    1 libxpc.dylib 0x00007fff79130366 _xpc_pipe_pack_message + 125
    2 libxpc.dylib 0x00007fff7913fae1 _xpc_pipe_simpleroutine + 58
    3 libxpc.dylib 0x00007fff79136b35 xpc_pipe_simpleroutine + 44
    4 libsystem_trace.dylib 0x00007fff7911ab4e ___os_activity_stream_reflect_block_invoke + 29
    5 libdispatch.dylib 0x00007fff78eb563d _dispatch_client_callout + 8
    6 libdispatch.dylib 0x00007fff78eb8374 _dispatch_block_invoke_direct + 256
    7 libdispatch.dylib 0x00007fff78eb8254 dispatch_block_perform + 124
    8 libsystem_trace.dylib 0x00007fff7911a5fa _os_activity_stream_reflect + 530
    9 libsystem_trace.dylib 0x00007fff7911e1f5 _os_log_impl_stream + 571
    10 libsystem_trace.dylib 0x00007fff7911365c _os_log_impl_flatten_and_send + 7608
    11 libsystem_trace.dylib 0x00007fff79111885 _os_log_error_impl + 113
    12 com.apple.LaunchServices 0x00007fff4e509464 ___ZN22LSNotificationReceiver23getNotificationListenerEv_block_invoke.10 + 221
    13 libxpc.dylib 0x00007fff79136f08 _xpc_connection_call_event_handler + 56
    14 libxpc.dylib 0x00007fff79134e9e _xpc_connection_mach_event + 933
    15 libdispatch.dylib 0x00007fff78eb56dd _dispatch_client_callout4 + 9
    16 libdispatch.dylib 0x00007fff78eca0d6 _dispatch_mach_msg_invoke + 436
    17 libdispatch.dylib 0x00007fff78ebb792 _dispatch_lane_serial_drain + 268
    18 libdispatch.dylib 0x00007fff78ecac19 _dispatch_mach_invoke + 481
    19 libdispatch.dylib 0x00007fff78ec46ed _dispatch_workloop_worker_thread + 598
    20 libsystem_pthread.dylib 0x00007fff790f5611 _pthread_wqthread + 421
    21 libsystem_pthread.dylib 0x00007fff790f53fd start_wqthread + 13
    Thread 6:
    0 libsystem_kernel.dylib 0x00007fff7903a86a __psynch_cvwait + 10
    1 libsystem_pthread.dylib 0x00007fff790f956e _pthread_cond_wait + 722
    2 net.maxon.cinema4d 0x0000000101d9c204 0x101bde000 + 1827332
    3 net.maxon.cinema4d 0x0000000101ccd301 0x101bde000 + 979713
    4 c4dplugin.xlib 0x0000000107925294 0x106729000 + 18858644
    5 net.maxon.cinema4d 0x0000000101c62daf 0x101bde000 + 544175
    6 net.maxon.cinema4d 0x0000000101be7099 0x101bde000 + 37017
    7 net.maxon.cinema4d 0x0000000101de6591 0x101bde000 + 2131345
    8 net.maxon.cinema4d 0x0000000101d82b58 0x101bde000 + 1723224
    9 libsystem_pthread.dylib 0x00007fff790f62eb _pthread_body + 126
    10 libsystem_pthread.dylib 0x00007fff790f9249 _pthread_start + 66
    11 libsystem_pthread.dylib 0x00007fff790f540d thread_start + 13
    Thread 7:
    0 libobjc.A.dylib 0x00007fff777471b6 std::__1::__hash_iterator std::__1::__hash_table::find(unsigned long const&) + 102
    1 libobjc.A.dylib 0x00007fff77730538 _object_remove_assocations + 163
    2 libobjc.A.dylib 0x00007fff77730462 objc_destructInstance + 106
    3 libobjc.A.dylib 0x00007fff777303e7 object_dispose + 19
    4 libxpc.dylib 0x00007fff7913fb01 _xpc_pipe_simpleroutine + 90
    5 libxpc.dylib 0x00007fff79136b35 xpc_pipe_simpleroutine + 44
    6 libsystem_trace.dylib 0x00007fff7911ab4e ___os_activity_stream_reflect_block_invoke + 29
    7 libdispatch.dylib 0x00007fff78eb563d _dispatch_client_callout + 8
    8 libdispatch.dylib 0x00007fff78eb8374 _dispatch_block_invoke_direct + 256
    9 libdispatch.dylib 0x00007fff78eb8254 dispatch_block_perform + 124
    10 libsystem_trace.dylib 0x00007fff7911a5fa _os_activity_stream_reflect + 530
    11 libsystem_trace.dylib 0x00007fff7911e1f5 _os_log_impl_stream + 571
    12 libsystem_trace.dylib 0x00007fff7911365c _os_log_impl_flatten_and_send + 7608
    13 libsystem_trace.dylib 0x00007fff79111885 _os_log_error_impl + 113
    14 com.apple.LaunchServices 0x00007fff4e4f80b9 _LSCopyApplicationInformation + 4205
    15 com.apple.AppKit 0x00007fff4a4ea162 -[NSRunningApplication _fetchDynamicProperties] + 516
    16 com.apple.AppKit 0x00007fff4aecda1b -[NSRunningApplication isActive] + 57
    17 c4dplugin.xlib 0x00000001067ef367 0x106729000 + 811879
    18 c4dplugin.xlib 0x00000001067ef0ed 0x106729000 + 811245
    19 net.maxon.cinema4d 0x0000000101de6591 0x101bde000 + 2131345
    20 net.maxon.cinema4d 0x0000000101d82b58 0x101bde000 + 1723224
    21 libsystem_pthread.dylib 0x00007fff790f62eb _pthread_body + 126
    22 libsystem_pthread.dylib 0x00007fff790f9249 _pthread_start + 66
    23 libsystem_pthread.dylib 0x00007fff790f540d thread_start + 13
    Thread 8:
    1 libsystem_pthread.dylib 0x00007fff790f95a1 _pthread_cond_wait + 773
    2 net.maxon.cinema4d 0x0000000101d9c192 0x101bde000 + 1827218
    4 network.module.xlib 0x000000010283ff23 0x1027cc000 + 474915
    5 network.module.xlib 0x0000000102844b3d 0x1027cc000 + 494397
    6 net.maxon.cinema4d 0x0000000101de6591 0x101bde000 + 2131345
    7 net.maxon.cinema4d 0x0000000101d82b58 0x101bde000 + 1723224
    8 libsystem_pthread.dylib 0x00007fff790f62eb _pthread_body + 126
    9 libsystem_pthread.dylib 0x00007fff790f9249 _pthread_start + 66
    10 libsystem_pthread.dylib 0x00007fff790f540d thread_start + 13
    Thread 9:
    0 libsystem_kernel.dylib 0x00007fff7903e61a __select + 10
    1 network.module.xlib 0x000000010284c18e 0x1027cc000 + 524686
    2 network.module.xlib 0x0000000102872fe6 0x1027cc000 + 684006
    3 network.module.xlib 0x0000000102872bb3 0x1027cc000 + 682931
    4 net.maxon.cinema4d 0x0000000101de6591 0x101bde000 + 2131345
    5 net.maxon.cinema4d 0x0000000101d82b58 0x101bde000 + 1723224
    6 libsystem_pthread.dylib 0x00007fff790f62eb _pthread_body + 126
    7 libsystem_pthread.dylib 0x00007fff790f9249 _pthread_start + 66
    8 libsystem_pthread.dylib 0x00007fff790f540d thread_start + 13
    Thread 10:: NetworkServiceBus jobqueue #0: 0x7fed7115bfc0 (Q 0x7fed7018bc80
    3 net.maxon.cinema4d 0x0000000101cfe4f6 0x101bde000 + 1180918
    4 net.maxon.cinema4d 0x0000000101cfdfc7 0x101bde000 + 1179591
    5 net.maxon.cinema4d 0x0000000101de6430 0x101bde000 + 2130992
    6 net.maxon.cinema4d 0x0000000101de65ea 0x101bde000 + 2131434
    Thread 11:
    4 net.maxon.cinema4d 0x0000000101cfe148 0x101bde000 + 1179976
    Thread 12:: Default Queue #0: 0x7fed80081f40 (Q 0x102006880, Id 0x70000f9c7
    Thread 13:: Default Queue #1: 0x7fed80087ec0 (Q 0x102006880, Id 0x70000faca
    Thread 14:: Default Queue #2: 0x7fed8008de40 (Q 0x102006880, Id 0x70000fbcd
    Thread 15:: Default Queue #3: 0x7fed80093dc0 (Q 0x102006880, Id 0x70000fcd0
    Thread 16:: Default Queue #4: 0x7fed80099d40 (Q 0x102006880, Id 0x70000fdd3
    Thread 17:: Default Queue #5: 0x7fed8009fcc0 (Q 0x102006880, Id 0x70000fed6
    Thread 18:: Default Queue #6: 0x7fed800a5c40 (Q 0x102006880, Id 0x70000ffd9
    Thread 19:: Default Queue #7: 0x7fed800abbc0 (Q 0x102006880, Id 0x7000100dc
    Thread 20:: Default Queue #8: 0x7fed70023080 (Q 0x102006880, Id 0x7000101df
    Thread 21:: Default Queue #9: 0x7fed70029000 (Q 0x102006880, Id 0x7000102e2
    Thread 22:: Default Queue #10: 0x7fed7002ef80 (Q 0x102006880, Id 0x7000103e
    Thread 23:: Default Queue #11: 0x7fed70034f00 (Q 0x102006880, Id 0x7000104e
    Thread 24:: Reuse Resource Queue #0: 0x7fed80e9b080 (Q 0x7fed606280c0, Id 0
    Thread 25:: SessionLog sync queue #0: 0x7fed80e980c0 (Q 0x7fed6062aa00, Id
  • Ian Davies
    December 6, 2019 at 12:41 pm
    Something I just noticed and I’m not sure how much difference it might make, but @Mike Compas’s post about working versions of the MobileDevice.framework lists the version number as 988.222.1 whereas the version number of the file posted by @Xavier is 988.250.11.100.2
    Does anyone actually have version 988.222.1 that they can post, just so I can be sure?
  • Xavier Bonet
    December 6, 2019 at 12:44 pm
    Ok—so, again, remember: “stumbling in the dark”—having said that, if I were you these are the things I would look into:
    EXC_BAD_ACCESS (SIGSEGV)—that’s your problem there, it seems to me. At least, from what I’ve found right now, this is the important bit:
    “EXC_CORPSE_NOTIFY is irrelevant. The important information is in the Exception Type (EXC_CRASH (SIGABRT)) and the backtrace.”(https://stackoverflow.com/questions/34804117/got-a-exc-corpse-notify-symbol-crash-how-to-track-it)
    And here:
    “From your description I suspect the most likely explanation is that you have some error in your memory management.” (https://stackoverflow.com/questions/327082/exc-bad-access-signal-received)
    Then, the only reference to the crash I see is: “Thread 0 Crashed:: Dispatch queue: com.apple.main-thread”
    Can’t find anything specific about that, except that they recommend you use the Crashes Organizer to find out specifics about what the crash codes mean. Maybe this will help: https://help.apple.com/xcode/mac/current/#/dev861f46ea8
    I’ll keep looking around to see if I find anything more relevant. But perhaps a forum member better informed about the ins-and-outs of how the macOS works will jump in and save the day!
    P.S. Remember to reenable your System Integrity Protection after you’re done moving stuff around. It really should remain enabled.
  • Ian Davies
    December 6, 2019 at 2:10 pm
    I appreciate your thoughts. I don’t think it’s a memory hardware issue (is that what you meant?) since nothing else is exhibiting any problem, and it literally happened right after a software update, which matches the trigger point you and others experienced.
    Only differences are that my update was a full OS combo updater rather than a single specific component (i.e. iTunes) and replacing the MobileDevice.framework hasn’t worked for me. So far, at least. Did you see my comment above about the version numbers of “working” copies of the framework? That’s one of the things that seems different for me at the moment.
    Interestingly, the response that Brian Jones posted from Maxon suggests updating to 10.14 (already on 10.14.6!) or re-installing the current OS, yet it was applying the combo updater that seemed to cause the problem in the first place.
    The other thing I may try is installing a fresh copy of Mojave on an external drive, booting off that then reinstalling C4D and seeing if that runs. Fun weekend ahead for me!
  • Brian Jones
    December 6, 2019 at 3:41 pm
    Xavier’s advice to change the MobileDevice.framework is what fixed it for me. That and never allowing that iTunes to update on those Macs with an older OS on them (10.11 El Cap for me) when I plug my phone in, which is what started the problem.
  • Page 3 of 5
