Activity Forums AJA Video Systems Audio Crackles from FCP 7 through Kona Card
  • Audio Crackles from FCP 7 through Kona Card
    Posted by Jake Diamond on July 12, 2010 at 6:23 pm
    Hello,
    My system was recently upgraded to FCP 7.02 from 6.05 and the Kona LHi control panel was upgraded to Version 8.0. I’m working on a Pro Res 1080i 29.97 sequence and now when I play any clips or sequences externally, the audio crackles and sometimes there are thin lines through the video on the external monitor. If I play the clips with External Video Monitoring turned off, the clips are fine, no crackling, no lines – only when playing everything externally. This is a problem because I’m going to have to output to HDCAM in a few days.
    If anyone has experienced this, or has any ideas on how to fix it, I’d greatly appreciate any advice.
    Thank you,
    Jake
    OS 10.5.8
    2 x 2.66 GHZ Quad-Core Intel Xeon
    8 GB 1066 MHz DDR3
    FCP 7.02
    Quicktime 7.6.6
    Aja Sales department replied 16 years, 1 month ago 8 Members · 29 Replies
  • 29 Replies
  • Jeremy Garchow
    July 12, 2010 at 6:50 pm
    [Jake Diamond] “and the Kona LHi control panel was upgraded to Version 8.0”
    Did you uninstall the older drivers before installing the new ones?
  • Jake Diamond
    July 12, 2010 at 7:13 pm
    Jeremy,
    I don’t know – someone else did the upgrade. Is there a way I can check?
    Jake
  • Jeremy Garchow
    July 12, 2010 at 7:14 pm
    [Jake Diamond] “I don’t know – someone else did the upgrade. Is there a way I can check? “
    Do another uninstall and reinstall.
  • Jake Diamond
    July 12, 2010 at 7:19 pm
    OK, thank you!
    Jake
  • Gary Adcock
    July 12, 2010 at 7:24 pm
    [Jeremy Garchow] “Did you uninstall the older drivers before installing the new ones?”
    AND did you update the firmware manually? it is not an automatic process.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Technology Development
    Quality Assurance Assistance
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Jake Diamond
    July 12, 2010 at 7:40 pm
    Gary,
    Sorry – I should have done more research before asking – I don’t know the answer to this either as it was done over the weekend and I have no idea what they exactly did. I will find out to gather more data.
    Thank you,
    Jake
  • Michael Sacci
    July 12, 2010 at 8:03 pm
    I had this problem a while back, the audio not the video, with my Kona3. It was suggested that I route all the computer audio to the Kona. This stopped the crackles for me. Have not seen a negative side effect. I turn off the annoying alert sounds anyway but that is a must or else the bonk will make you jump out of your seat.
  • Jake Diamond
    July 12, 2010 at 10:34 pm
    Thanks Michael. I tried this and it fixed it in some places, but not all. It seems pretty random.
    Jake
  • Olivier Aubut
    July 13, 2010 at 1:05 pm
    Hi guys
    I have the same problem with fcp 7.0.2, osx 10.6.3 and kona LHi 8.0 on an octo, 16GB Ram. It’s a brand new system so the kona never was on a previous version. Everything is up to date.
    I tried the 8.0 NDD but it still has the same problem.
    I will try to downgrade the control panel and the firmware. Hope it’ll help.
    Please let me know if you have any other suggestions.
    Olivier
    Edit: ooh and I tried Michael’s suggestion to route the system audio to the kona. It did not fix the problem.
  • Michael Gossen
    July 13, 2010 at 5:32 pm
    What is your “Ref In” set to? Do you have a stable BB or tri-level sync?
    Michael Gossen
    Helium Digital Media
Page 1 of 3
