Activity › Forums › AJA Video Systems › Audio Crackles from FCP 7 through Kona Card
Aja Sales department replied 16 years, 2 months ago 8 Members · 29 Replies
Olivier Aubut
July 13, 2010 at 5:39 pmThanks Michael
My Genlock is set to Freerun. I don’t have a deck, I mainly use the Kona for monitoring as I work with file-based XDcam.Would a BB do the trick?
Sorry Jake for hijacking your post.
Michael Gossen
July 13, 2010 at 6:21 pmHmmm… Freerun should be fine. You shouldn’t need a BB signal for just monitoring. No deck connected? Any SDI input?
Michael Gossen
Helium Digital Media -
Olivier Aubut
July 13, 2010 at 6:33 pmNo input at all. The monitor is connected component and the audio directly connected to the speakers using AES/EBU.
I’m cutting some XDcam 1080p30 stuff and since my monitor does not have an sdi input, I have to monitor through component at 1080i29,97. I read somewhere else that the crackling might be because I’m monitoring at another res.
I might try to connect my broadcast monitor through HDMI/DVI.
Is HDMI good enough for grading?Thanks for your help.
Olivier -
Jeremy Garchow
July 13, 2010 at 6:37 pm[Olivier Aubut] “I’m cutting some XDcam 1080p30 stuff and since my monitor does not have an sdi input, I have to monitor through component at 1080i29,97. I read somewhere else that the crackling might be because I’m monitoring at another res. “
What ‘res’ are you monitoring?
1080p30 XDcam and 1080i29.97 are really the same thing, that is your 1080p XDcam can be monitored @ 1080psf29.97 (which is the 1080i setting on the Kona @ 29.97 fps).
Jeremy
Michael Gossen
July 13, 2010 at 6:43 pmWhat speakers do you have? Have you tried the analog audio outs?
Michael Gossen
Olivier Aubut
July 13, 2010 at 6:53 pmThanks Jeremy – I wasn’t aware of this. So I bet using an HDMI won’t make a difference.
Michael – The analog audio had the same problem. I have Roland DS-5 speakers.
Thanks for your suggestions guys
Olivier Aubut
July 13, 2010 at 7:02 pm24bit.
But the problem isn’t only in the audio. Just like the OP, I have some thin horizontal white lines on the output video. -
Jeremy Garchow
July 13, 2010 at 7:06 pm[Olivier Aubut] “24bit.
But the problem isn’t only in the audio. “ANd your footage is 16bit I take it?
[Olivier Aubut] “Just like the OP, I have some thin horizontal white lines on the output video.”
What else do you have in the ay of PCI cards in your mac? This sounds like either a configuration issue or mismatched settings.
Olivier Aubut
July 13, 2010 at 7:13 pmI have a mix of 16 and 24bit audio in a 24bit sequence.
The LHi is in slot 2 and I have a Caldigit PCI-E card in slot 4.
