Activity › Forums › AJA Video Systems › Audio Crackles from FCP 7 through Kona Card
Aja Sales department replied 16 years, 1 month ago 8 Members · 29 Replies
Jeremy Garchow
July 13, 2010 at 7:15 pmI’d put the raid on slot 2 and Kona in slot 3.
The mixed audio is probably causing your crackles as well.
Jeremy
Olivier Aubut
July 13, 2010 at 7:28 pmThanks – I’ll give it a try.
I Changed the sequence bit depth and the crackling is happening on both 16 and 24bit. So I doubt that this is the problem.
Hopefully the card order will help.
I’ll post the results.
Thanks Jeremy -
Jeremy Garchow
July 13, 2010 at 7:33 pm[Olivier Aubut] “I Changed the sequence bit depth and the crackling is happening on both 16 and 24bit. So I doubt that this is the problem. “
But that still leaves you with mixed audio sources.
Olivier Aubut
July 13, 2010 at 7:46 pmSorry, I wasn’t clear at all.
I tested some 16bit footage on a 16bit sequence and some 24bit footage on a 24bit sequence. Audio problems on both.
Am I missing something?
Jeremy Garchow
July 13, 2010 at 7:48 pm[Olivier Aubut] “Am I missing something?”
No, I missed it. I get crackles sometimes if my audio isn’t lined up (44.1 vs 48, 16 vs 24, etc). It has been a really long time, though. It’s also troubling that you are getting video hits. Something doesn’t seem like it’s configured correctly.
Jeremy
Olivier Aubut
July 13, 2010 at 10:07 pmWell, the reorder didn’t fix the problem but the downgrade seems to have done the trick.
I’m now on control panel 7.5.1 NDD and there is no more crackling or video glitches. Huzza!I hope someone from AJA reads this.
Thanks for your help Jeremy
Olivier -
Mike Weber
July 13, 2010 at 11:17 pmWe just installed a Kona LHi last week, and were experiencing the exact same problem – random audio crackling and video hits. I followed your lead – uninstalled Kona LHi Driver 8.0, installed 7.5.1, and all is well so far – crackling and hits are gone. Thanks for sharing your solution!
Mike
Jake Diamond
July 13, 2010 at 11:36 pmThanks to everyone for your help! Yes, reinstalling 7.5.1 fixed it.
July 15, 2010 at 9:56 pmThere is a new release for the KONA LHi. The new release version is 8.0.1. This release addresses a KONA LHi issue where some users experienced intermittent glitches in video and audio. Features and improvements are otherwise exactly the same as the version 8.0 driver.
Visit the AJA website at the following URL to obtain this version:
https://www.aja.com/support/konaNEW/kona-lhi.php—
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
