Zoom-level shortcut key?
Posted by Dale Spetz on November 28, 2007 at 2:02 pmIs there a way to setup a shortcut key to instantly achieve a favorite zoom-level on the tracks?
I realize that Vegas8 allows you to shortcut to project-view level, frame level, and a 1-sec. level, but are any of these pre-set shortcut levels adjustable? My most frequently used zoom-level is none of those that they provide. It would be nice to get to it with one button push.
Ron Shook replied 18 years, 10 months ago 3 Members · 11 Replies -
Edward Troxel
November 28, 2007 at 3:22 pm -
Dale Spetz
November 28, 2007 at 3:28 pmThanks for your reply, Edward. I have your Excalibur, but I don’t have a clue as to how to set up scripts. Is there a tutorial that can walk me through this?
Edward Troxel
November 28, 2007 at 3:44 pmVegas 8 added many new scripting commands. One of them will set the zoom level of the timeline. Since you know nothing about writing scripts, someone would need to write it for you.
Try this one:
https://www.jetdv.com/scripts/SetZoomLevel.csThis will set the timeline to 1 minute 30 seconds long. In the middle is this line:
Timecode zoomSize = new Timecode(“00:01:30:00”);Change that timecode to be the length you want.
Put this script in the following folder (you may have to create it):
{My Documents}\Vegas Script Menu
Then, after starting Vegas, you should be able to assign that to any keypress you desire.
Dale Spetz
November 28, 2007 at 4:41 pmThank you, Edward. I successfully copied and installed that script in Vegas8, as you instructed—and it works as you designed. But, to modify the “time” portion of it, what program would I use?
Modifying it in Notepad or Frontpage, it is not recognized as a .cs file, even if I name it as a .cs file.
Edward Troxel
November 28, 2007 at 5:57 pm -
Dale Spetz
November 28, 2007 at 6:48 pmYou are right, of course. I don’t know what I was doing, before, but modifying the 2nd time within Notepad works, just fine.
Thank you, Edward!
Dale Spetz
November 28, 2007 at 7:50 pmThat is such a great time saver—being able to return to my preferred zoom level by pressing one key with my left hand!
Do you happen to have a similar script that jumps to a preferred track height?
Dale Spetz
November 28, 2007 at 7:51 pmEdward, that is such a great time saver—being able to return to my preferred zoom level by pressing one key with my left hand!
Edward Troxel
November 28, 2007 at 8:14 pm -
Dale Spetz
November 28, 2007 at 8:43 pmWell, then that was very kind of you, sir. Thank you! Its big help and will save thousands of two-handed-shortcut zoom adjustments.
