Activity › Forums › Adobe After Effects › Z Space Distribution with Photoshop Layers
Posted by Nicholas Bierzonski on March 27, 2009 at 1:31 pmIs there a way to Z Space Distribute Photoshop Layers so the perspective does not change. I found a plugin from Zaxwerks that can do this. I have no problem purchasing it if After Effects CS3 can’t do this internally.
The link below will illustrate better what I am trying to execute.https://zaxwerks.com/layertools/details.shtml#Z-Distribution
-Nicholas Bierzonski
Senior Editor/DVD Author/Java Boy
http://www.finalfocusvideo.com
Jason Brown replied 16 years, 8 months ago 5 Members · 7 Replies -
Richard Harrington
March 27, 2009 at 2:00 pmYo can of course do this manually… but automated… no
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
Todd Kopriva
March 27, 2009 at 2:32 pmSee the comment at the bottom of the “Preparing and importing Photoshop files” page of After Effects Help for a link to a script from Paul Tuersley that does this.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
Nicholas Bierzonski
March 27, 2009 at 2:37 pmThanks for the reply!
To do this manually I would have to move the object in Z space then scale the object up to fill the screen. Correct? I have multiple layers that I want to appear in 3D space during a camera zoom. When the camera reaches it’s final position the layers need to appear as a flat poster.
I found a motion 3 tutorial that does what I’m trying to do.
Ken Stone Motion 3 Tutorial:
Click on Motion then
– Animating Photoshop Layers in Z-Space (Movie) – by Mark Spencer
https://www.kenstone.net/fcp_homepage/fcp_homepage_index.htmlIs it possible to do this in After Effects without the Zaxwerks plugin? Is there a tutorial you could point me to that would help?
Nicholas Bierzonski
March 27, 2009 at 8:21 pmThanks for your help. I managed to find combination solution. I probably will end up buying that plugin anyway. It makes some complex After Effect moves quick and easy.
Jason Brown
April 2, 2009 at 12:22 amThe best way I’ve found to do this is import the layered PSD you are animating (in my case, anyway) and make sure you import it as COMP SIZE…this places the anchor point at the exact same place on all layers…then distribute in Z space and scale to fill screen.
That is the best workaround besides buying the Zakwerks plugin.
Josh Sliffe
January 4, 2010 at 8:06 pmhey their definitly is a script to do what your talking about.. to be able to push things back in z space but as you do they automatically scale up to keep perfect perspective.
Lemme know if your still needing this and i’ll give it to ya.
Jason Brown
January 4, 2010 at 8:16 pmI purchased Layer Tools from Zaxwerks a couple months ago…it makes SHORT WORK of this process…it’s amazing. There are other options inside of it to do many other things I haven’t explored. it is WAY worth the price of the plug-in.
-Jason
