Activity Forums AJA Video Systems XENA LH Premiere CS3 issues.
  • XENA LH Premiere CS3 issues.
    Posted by Tim Coates on January 18, 2008 at 1:31 pm
    We are experiencing playback problems with our Xena LH/Premiere CS3.
    Firstly, the audio is around 3 frames out of sync when using the AJA ASIO.
    The main problem however is that play/pause command will sometimes take a few seconds to respond, sometimes it won’t respond at all and Premiere will have to be restarted. This happens about 30 times a day and makes editing virtually impossible.
    Has anyone else had similar experiences? Is it a faulty card or a common problem?
    Any thoughts much appreciated.
    Tim
    Ken Schreiner replied 18 years, 6 months ago 6 Members · 25 Replies
  • 25 Replies
  • Ted Barnett
    January 18, 2008 at 1:54 pm
    Tim
    It sounds to me like a hardware conflict…Try moving the card to a different slot…
    I have a LHe in a HP 8400…Constant crashes…moved card to a Dell 670…works like a charm…
    I then put a Axio Le in the HP box..It now works like charm..
    No reinstall of any software….
    I think it’s to many devices sharing the same IRQ…
    Ted Barnett
    LoneWolf Interactive
  • Greg Beckt
    January 26, 2008 at 11:33 pm
    This happened to me as well. I believe it’s a QT issue.
    I changed my project to AVI and everything was back to normal.
    Greg
  • Tim Coates
    January 27, 2008 at 9:49 pm
    I don’t think it’s that as we soley use AVI. Incidentally, we have the same problem whether it’s SD or HD. Any other ideas? Is everyone else completely happy with the performance of this hardware when used with Premiere? It’s literally unusable for us at the moment.
    Any suggestions much appreciated.
    TC
    Kind Regards
    Tim Coates
    The Electric Picture Co.
    London – Brighton UK
  • Thad_h
    February 13, 2008 at 9:48 pm
    Tim,
    Can you give specifics please about:
    Disk System and controller
    Computer System
    Operating System
    Project Resolution/framerate
    File type you’ve captured to
    What you’re describing is neither a common problem, nor a symptom of a faulty board. It sounds like you have a data bottleneck somewhere in your system.
  • Shawn michael Lee
    February 18, 2008 at 5:50 pm
    I am also experiencing similar problems since upgrading from 2.0 to CS3. I installed the newest drivers for XENA LS. Now, in an AJA project, I lose all control when working in the timeline. Tapping the space bar or J-K-L keys can take from a half second to 4 SECONDS(!) to get a response.
    If I import the same footage (.avi using DV codec) into a default Adobe project, one that does not use the XENA card, I have full control.
    Again, this has only started happening after the upgrade. I was fine with PPro2.0 and whatever AJA driver I was using at the time (sorry, I don’t know which one I had installed then).
    Any thoughts?
  • Thad_h
    February 19, 2008 at 5:08 pm
    Shawn,
    Can you describe your situation in more detail?
    1) Are you having problems with a project that you started in CS2, then converted to CS3? Or one that you started in CS3? Or both?
    2) Are all your clips DV clips?
    3) Does this occur in a new project with only one clip loaded, or does it just occur in larger projects with hundreds of assets loaded?
    4) Can you specify your system specs for us?
    AJA XENA Support
  • Shawn michael Lee
    February 19, 2008 at 7:24 pm
    1)both. Creating a new project or opening an old one yields the same results.
    2)Yes. To be sure, I captured new DV footage. Same problem. I capture 8-bit AJA avi, no problem.
    3)My first project was with many DV clips. A later test project with only one or two clips produced the same results.
    4)HP xw9300 Workstation with 2 dual core Opterons, Nvidia FX3450, Creative Xi-Fi, Xena LS, Adobe CS3 Production Premium, 4GB mem, 500GB RAID 0 drives.
    Also of note: 1) I installed the P2 card manager for Panasonic DVCProHD at the same time. 2) If I remove/delete the audio from the DV files, the lag seems to disappear.
    Thanks.
  • Thad_h
    February 20, 2008 at 1:19 am
    Shawn Michael,
    I have been trying to reproduce the problem you’re describing and have not been able to do it.
    1) Do you have the latest drivers for your graphics card installed?
    2) Do you have ALL available windows updates installed?
    3) What is the source of your DV Files? are you capturing them via firewire? If so, could you attach a couple of tiny (only a few frames each) files to an email to support@aja.com so we can try to test them here?
    AJA XENA Support
  • Shawn michael Lee
    February 20, 2008 at 4:45 pm
    AJA XENA Support
    1)I have the same video drivers that were current as of Dec07. I don’t think that there has been an update since then.
    2)All Windows updates are installed.
    3)Some files are firewire. Some were SDI captured to DV25 Quicktime coded in Machina. I will send yo ua sample later today.
    Thanks.
  • Tim Coates
    February 20, 2008 at 4:48 pm
    Hi AJA support, answers below:
    Disk System and controller: Infortrend RAID with 24 x 750GB SATA connected via 2 x 4GB FC
    Computer System: Asus DSGC-DW with 2 x Quad Xeon 2.66GHz
    Operating System: Win XP sp2
    Project Resolution/framerate: ALL
    File type you’ve captured to: AVI
    Tim
    Kind Regards
    Tim Coates
Page 1 of 3
