Activity › Forums › AJA Video Systems › XENA LH Premiere CS3 issues.
Tim Coates
February 28, 2008 at 4:04 pmHey, this works for us too! We do kinda need the audio meters though..
Kind Regards
Tim Coates
The Electric Picture Co.
London – Brighton UK -
Shawn michael Lee
February 28, 2008 at 5:35 pmYou only need to hide the master meter. You can leave all of the channel meters visible.
If you want, you can then go to Window>Audio Master Meters.
The lag will be back, but not nearly as bad. -
Thad_h
February 28, 2008 at 6:17 pmHi Shawn and Tim,
Thanks from both of you for helping us diagnose this one. As Shawn said, we can now see the problem quite easily, now that we know the audio mixer must be open, and the master exposed to reproduce this problem. We’re looking into it further now.
As shawn specified, hiding the master level meter in the audio mixer is an easy workaround for the time being.
AJA XENA Support
Ken Schreiner
March 2, 2008 at 4:15 pmI have the same problem with spacebar/pause but deleting audio clips and hiding the audio meters doens’t work. This is a custom work station. I’d be happy to share the specs if someone from AJA would like them.
Ken Schreiner
March 2, 2008 at 11:07 pmBTW Shawn: Thanks for the tip! Playing back 720×480 in 720×486 makes my spacebar work correctly. It’s a hassle going back and forth but I have little choice.
