Activity Forums Apple Final Cut Pro Legacy XDCAM HD422 QuickTime to Avid
  • XDCAM HD422 QuickTime to Avid
    Posted by James Fuller on March 24, 2009 at 3:40 pm
    Here’s a question for those familiar with FCP, Avid, and Sony’s XDCAM HD422 codec.
    I have a load of footage (over 3000 shots) captured using FCP and used for regular edits for a long term client. The majority of the footage is SD (PAL) in ProRes 422 codec. However, there is some newer HD footage in XDCAM HD422 1080i.
    I’ve been asked to provide the footage to an Avid based facility. And so begins my dilemma:
    Obviously, making dubs of all the original rushes will take too long, and is not very cost effective for anyone involved.
    The simplest method would be to copy the drive and send them my pre-captured files. As far as I understand, their Windows based Avid will be able to accept my ProRes files, but there is currently no QuickTime XDCAM codec for Windows. So, my options are:
    1 – convert the XDCAM HD422 .movs to ProRes 422. (will this work?)
    2 – backup the original XDCAM discs to the drive and let them sort it themselves.
    Any advice or alternative options would be appreciated.
    Thanks in advance
    James Fuller replied 17 years, 6 months ago 3 Members · 4 Replies
  • Shane Ross
    March 24, 2009 at 3:58 pm
    Get them the camera original files. For them to try to deal with anything you already imported into FCP might be not worth it. IF you want to send them ProRes, they will need the ProRes Decoder…
    https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Windows
    Native XDCAM they will not see at all. But if you give them the originals, they can then immediately convert those to the Avid format and not have to deal with the FCP codecs at all.
    Shane
  • Andy Mees
    March 24, 2009 at 4:12 pm
    …but there is currently no QuickTime XDCAM codec for Windows.
    Ah, but there is. Your client needs to buy (or you need to provide them with) the Calibrated Q XDDecode quicktime component for Windows. That, together with Apple’s ProRes Decode component for Windows should let the Avid work with any of these pre-imported quicktime movie files
    https://www.calibratedsoftware.com/QXD.asp
  • Shane Ross
    March 24, 2009 at 4:17 pm
    Ah…I keep forgetting about that.
    OK…if they want to spend MONEY…that is the way to go. If they want pain free, and cost free, then get them the camera originals.
    Shane
  • James Fuller
    March 24, 2009 at 4:34 pm
    OK – great. Calibrated XD Decoder is an option – the cost is quite minimal if I take into account how long the XDCAM discs will take to back up from scratch (there are over 20 discs).
    Thanks for you help!
    James
