Activity Forums Adobe After Effects write a script to run another script
  • write a script to run another script
    Posted by Amanda Russell on June 19, 2018 at 12:44 am
    Looking forward to ideas…
    I’m trying to build a UI Script Panel I can send to our third party designers so they can quickly convert and animate some files for us. I have the panel built, but the tools we use internally are mostly presets and a few scripts.
    I figured out how to apply a preset to the selected layer from the preset .ffx file (panel 3/button 1 for Fly In/Out), but I’m not sure how to make the buttons run a script in the same way (by referencing a specific .jsx file). So currently, panel 1/button1 for Fade In works, but I’d like it to use the script file instead so if I need to make changes internally, I don’t have to also edit the panel for our external designers – just send everyone the same updated fadeIn.jsx to replace.
    Code below:
    function myScript(thisObj) {
    function myScript_buildUI(thisObj) {
    var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "PPT Toolbar", undefined, {resizeable:true});
    res="group{orientation:'row', alignment:['fill', 'fill'], alignChildren:['fill', 'fill'],\
    myPanelOne: Panel{text:'Entrance Effects', orientation:'column', alignChildren:['fill', 'top'],\
    myPanelOneButton1: Button{text:'Fade In'},\
    myPanelOneButton2: Button{text:'Zoom In 0-100'},\
    myPanelOneButton3: Button{text:'Zoom In 1000-100'},\
    myPanelOneButton4: Button{text:'Grow & Spin In'},\
    myPanelOneButton5: Button{text:'Swivel In'},\
    myPanelOneButton6: Button{text:'Wheel In'},\
    myPanelOneButton7: Button{text:'Stretch'},\
    myPanelOneButton8: Button{text:'Expand'},\
    myPanelOneButton9: Button{text:'Spiral'},\
    myPanelTwo: Panel{text:'Exit Effects', orientation:'column', alignChildren:['fill', 'top'],\
    myPanelTwoButton1: Button{text:'Fade Out'},\
    myPanelTwoButton2: Button{text:'Zoom Out 100-0'},\
    myPanelTwoButton3: Button{text:'Zoom Out 100-1000'},\
    myPanelTwoButton4: Button{text:'Grow & Spin Out'},\
    myPanelTwoButton5: Button{text:'Swivel Out'},\
    myPanelTwoButton6: Button{text:'Wheel Out'},\
    myPanelTwoButton7: Button{text:'Collapse'},\
    myPanelTwoButton8: Button{text:'Contract'},\
    myPanelThree: Panel{text:'Dual Effects', orientation:'column', alignChildren:['fill', 'top'],\
    myPanelThreeButton1: Button{text:'Fly In/Out'},\
    myPanelThreeButton2: Button{text:'Rise/Sink'},\
    myPanelThreeButton3: Button{text:'Float In/Out'},\
    myPanelThreeButton4: Button{text:'Peek In/Out'},\
    myPanelThreeButton5: Button{text:'Wipe In/Out'},\
    myPanelThreeButton6: Button{text:'Split Wipe In/Out'},\
    myPanelFour: Panel{text:'Additional Effects', orientation:'column', alignChildren:['fill', 'top'],\
    myPanelFourButton1: Button{text:'Blink'},\
    myPanelFourButton2: Button{text:'Teeter'},\
    myPanelFourButton3: Button{text:'Pulse'},\
    myPanelFourButton4: Button{text:'Bounce'},\
    myPanelFourButton5: Button{text:'Typewriter Text'},\
    myPanelFourButton6: Button{text:'Wave Text'},\
    myPanelFourButton7: Button{text:'Drop Shdw Far'},\
    myPanelFourButton8: Button{text:'Drop Shdw Near'},\
    myPanelFourButton9: Button{text:'Gradient BG'},\
    myPanelFive: Panel{text:'Other', orientation:'column', alignChildren:['fill', 'top'],\
    myPanelFiveButton1: Button{text:'Time Remap'},\
    myPanelFiveButton2: Button{text:'Chapter Marker'},\
    myPanelFiveButton3: Button{text:'styleGuide Fill'},\
    //Add resource string to panel
    myPanel.grp = myPanel.add(res);
    //Defaults
    //panel 1 button 1
    myPanel.grp.myPanelOne.myPanelOneButton1.onClick = function setOpacityKeyframes() {
    var selectedLayers = app.project.activeItem.selectedLayers;
    if (selectedLayers.length == 0) {
    throw new Error('Please select at least 1 layer.');
    for (var i = 0; i < selectedLayers.length; i++) {
    var fadeTime = 0.50
    var layer = selectedLayers[i];
    if (layer.property("Transform").property("Opacity").numKeys.length >= 1) {
    throw new Error('Layer "' + layer.name + '" has existing opacity keyframes. Disable opacity stopwatch and retry.');
    //layer.timeRemapEnabled = true;
    var keyframes = layer.property("Transform").property("Opacity");
    keyframes.setValueAtTime(layer.inPoint, 0);
    keyframes.setValueAtTime(layer.inPoint + fadeTime, 100);
    //keyframes.setInterpolationTypeAtKey(1, KeyframeInterpolationType.LINEAR, KeyframeInterpolationType.LINEAR);
    //panel 3 button 1
    myPanel.grp.myPanelThree.myPanelThreeButton1.onClick = function applyPreset(preset) {
    var preset = File ('/Applications/Adobe After Effects CC 2017/Presets/pptPresets2018/superFly.ffx');
    app.project.activeItem.layer(1).applyPreset(preset);
    //Setup panel sizing and make panel resizable
    myPanel.layout.layout(true);
    myPanel.grp.minimumSize = myPanel.grp.size;
    myPanel.layout.resize();
    myPanel.onResizing = myPanel.onResize = function () {this.layout.resize();}
    return myPanel;
    var myScriptPal = myScript_buildUI(thisObj);
    if ((myScriptPal != null) && (myScriptPal instanceof Window)) {
    myScriptPal.center();
    myScriptPal.show();
    myScript(this);
    Amanda Russell replied 7 years, 10 months ago 2 Members · 2 Replies
  • Walter Soyka
    June 19, 2018 at 10:29 am
    Two methods I can think of right away.
    1) If the script is installed in one of Ae’s default application or user script folders, it will appear as a menu item. That means you can call it as such:
    app.executeCommand(app.findMenuCommandId("myGreatScript.jsx"));
    2) If you know where the file sits on disk, you can call tell Ae’s scripting engine to evaluate it:
    $.evalFile("C:/path/to/myGreatScript.jsx");
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Amanda Russell
    June 19, 2018 at 6:26 pm
    Thank you! I have some customer work to get through, but I’m excited to try this out!
