Activity › Forums › Apple Final Cut Pro Legacy › workflow from Jpeg 2000 time line to SD DVD
  • workflow from Jpeg 2000 time line to SD DVD
    Posted by George Sloan on January 26, 2011 at 8:42 pm
    Please advise me as to the best Quality workflow beginning with an important 30 minute project that has been shot and edited in 1O80i …then rendered (with compression markers)to JPEG2000 or JPEG Photo.
    I have exported to quicktime conversion and the movie looks great but here this problem..
    When compressing to DVD SD 4:3 either directly to compressor or QT then compressor. I am getting less than desirable results in terms of picture/color quality when played back as a dvd. (the 16:9 letter boxing and aspect ratio is perfect)…Need advice on workflow/settings starting with the Jpeg timeline.
    Thanks George Sloan sloanmotion.com
    using—FCP 7
    Model Name: Mac Pro
    Model Identifier: MacPro1,1
    Processor Name: Dual-Core Intel Xeon
    Processor Speed: 2.66 GHz
    George Sloan replied 15 years, 8 months ago 4 Members · 12 Replies
  • 12 Replies
  • Hector Berrebi
    January 26, 2011 at 8:58 pm
    hi George
    can you describe “less than desirable” what are you seeing in the DVD that looks wrong?
    also, what was it shot on?
    and why the jpeg 2000 conversion? was it done by sequence settings?
    …dvd’s tend to generally look less than desirable when compared to their HD source
    hector
    Hector Berrebi
    Schibber Group
    prePost Consulting
  • George Sloan
    January 26, 2011 at 9:54 pm
    Thanks Hector
    less desirable means means that i would like to produce better quality image for final input
    to sd dvd…will use for for dvd distribution and local broadcast…but don’t let deter you from
    original question.. i use JPEG 2000 because I love it.
    Question is about workfow/settings see recent previous post
    George
  • George Sloan
    January 26, 2011 at 10:26 pm
    Thanks Hector
    Sorry about multiple posts but my first post. yesterday which was comprehensive is yet to be answered.
    To further answer your questions it was shot in a cannon xh a1 in 1O80i thus the 1080i timeline.
    Switched to Jpeg2000 in sequence settings and rendered full for 4 hours…now jerky in canvas.
    George
  • Rafael Amador
    January 26, 2011 at 10:37 pm
    – Avoid QT Conversion like the pest. No control on any process.
    – In Compressor set “Frame Control ON” and “Resize Filter” BEST or BETTER
    rafael
    http://www.nagavideo.com
  • Hector Berrebi
    January 27, 2011 at 6:33 am
    [george sloan] ” i use JPEG 2000 because I love it.”
    love makes people do all sorts of irrational things 🙂
    i would recommend the following workflow
    i believe you captured via FW to HDV files.
    next time
    capture to Prores HQ (you have a preset for that, HDV – Prores, in the audio video settings
    use a Prores sequence setting
    export quicktime movie using current settings – do not recompress all frames
    in compressor, do what Rafael recommended in his reply
    test this out for a short segment, and compare it to what you got previously
    hope this helps
    hector
    Hector Berrebi
    Schibber Group
    prePost Consulting
  • Paul Jay
    January 27, 2011 at 5:40 pm
    Rafael,
    I see you adapted my Compressor downscale advice
    Which wasn’t really good in your opinion right?
    I have to say, the FCP downscale solution is nice too, but not as good as Compressor Resize filter;)
  • George Sloan
    January 27, 2011 at 7:08 pm
    Thanks Hector,
    You and Rafael are good people!
  • Rafael Amador
    January 27, 2011 at 7:32 pm
    Hi Paul,
    Setting the “Frame Control ON” is not critical just because its allows to chose different filter “qualities”, but because allows Compressor works in 32b Floating Point (up to the Compressor manual).
    However, I have to say that, personally, I don’t think that FC (when set to High Precision and Motion Effects: BEST) makes a worst job than Compressor. In fact I doubt very much if is worth the pain of going to Compressor instead of downscaling in FC. I think that probably both use the same engine.
    Last year I made some serious (?) downscaling tests with all the applications I had available:
    – Compressor
    – Purifier
    – SHAKE.
    Since then, I only use SHAKE for any downscaling. The difference with the other applications is indescribable.
    Cheers,
    rafael
  • Hector Berrebi
    January 27, 2011 at 8:22 pm
    YW
    happy i could help
    Hector Berrebi
    Schibber Group
    prePost Consulting
  • Paul Jay
    January 27, 2011 at 9:52 pm
    Hm interesting. I will to some tests with Shake then.
    Compressor is nicer when you use a Cluster ( Qmaster settings )
    This way you can use all the cores in your MacPro in Compressor.
    Cheers.
