Activity › Forums › Adobe After Effects › Will be After Effects CS4 64 bit?
Posted by Jim Farlop on October 23, 2008 at 10:29 pmHi, I would like to know if finally After Effects CS4 will become 64 bit. If so, why there’s no mention of that in the adobe’s web?
The Shader
Benjamin Barber replied 17 years, 9 months ago 4 Members · 8 Replies -
Jim Farlop
October 24, 2008 at 9:43 pmSo, why in the trial version of AE CS4 only appears AE 32bits????
The Shader
Jason Milligan
October 25, 2008 at 12:32 amAre you talking about 64 bit processing or 64 bit color?
It definitely isn’t 64-bit color.
32 bit color is pretty impressive as is. -
Jim Farlop
October 25, 2008 at 10:01 amI mean 64bit code, being able to have more than 4gb memory for the program itself, like in Phoroshop CS4 64bit.
The Shader
Jason Milligan
October 27, 2008 at 5:12 pmWhat operating system are you using? Is it a 64 bit OS?
Also, I haven’t used CS4 yet, so I can’t guarantee it is 64 bit.
It was reported to be prior to release, but that may have changed. -
Kevin Camp
October 27, 2008 at 6:56 pmi actually thought it was only the pc version of photoshop that was 64-bit… i thought the rest of cs4 was only 32-bit. that was from early reports that i had read, i really hadn’t checked into it beyond that… still running cs3 here.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Jason Milligan
October 27, 2008 at 7:39 pmYou are probably right. I do specifically remember reading that Photoshop would be 64 bit. I thought I had read it would leak into AE and some other CS4 apps, but maybe that was wishful thinking on my part.
Benjamin Barber
November 5, 2008 at 5:32 amAE is not 64 bit encoded but it optimized for quad core and dual core processors. There is a really cool slider option that allows you to choose either longer ram previews or faster rendering. The option allocates any extra ram you have to the extra processor that might be available. Hope that helps.
