Activity › Forums › DaVinci Resolve › Will a GUI FX4000 be used for processing aswell?
Posted by Paul Jay on July 25, 2011 at 12:46 pmWhen you have only 2x FX4000 in a MacPro:
1 as Gui
2 as GPUWill the GUI FX4000 be used for processing aswell?
Dwaine Maggart replied 15 years, 2 months ago 10 Members · 13 Replies -
Paul Jay
July 25, 2011 at 1:23 pmOkay thank you.
Will this configuration work?
Because i can’t find a configuration like this in the Resolve Configuration Guide.Slot4 Decklink 3D
Slot3 FX4000
Slot2 FX4000
Slot1 GUI ( ati 5770 ) -
Christopher Adams
July 25, 2011 at 1:37 pmI’m not sure but I seem to remember that you won’t have enough power leeds and that you might overload the power supply if you try to branch them off and split them. I could be wrong but I think that is the main issue.
Christopher Tay
July 25, 2011 at 2:08 pmThat is correct. There are only two 6-pin power connectors on the motherboard which is only enough to power 1 x ATI 5770 and 1 x Quadro4000 cards. You won’t be able to put 2 x Quadro4000 cards in the Mac Pro…for that you will need an external PCIe expansion chassis like the Cubix Desktop 2 or Desktop 4.
-chrispy
Sascha Haber
July 25, 2011 at 2:51 pmY-cable is worth a try, but better is to use a simple GT120
A slice of color…
DaVinci 8.0.1b3 OSX 10.6.8
MacPro 5.1 2×2,4 24GB
RAID0 8TB eSata 6TB
GTX 285 / GT 120
Extreme 3D+ WAVE -
Paul Jay
July 25, 2011 at 3:27 pmSo when a GT120 is used for the GUI, it should work.
It’s just that this configuration ( GT120, FX4000, FX4000 , Extreme 3D ) is not listed in the Resolve Config Guide.
Eric Santiago
July 25, 2011 at 3:55 pmIs this true?
Im running v8.01 on a MP 12core with Quadro 4000 as GUI and REDRocket.
With R3D files Im getting 24fps on play back, of course on one extra node since I just started learning. -
Eric Santiago
July 25, 2011 at 4:01 pmJust to add that with my current config of Quadro 4000 as GUI, it does state in Resolve 8 that I have 1 GPU.
So does it work? -
Eric Fiegehen
July 25, 2011 at 5:54 pmKeep in mind Slots 3 & 4 are PCIe x4 electrical only. Even if you get a 16-channel card like Quadro 4000 running in either of these slots, they won’t receive full PCIe x16 bandwidth. This would apply to RED Rocket (PCIe x8) or ATTO’s dual or quad channel HBAs (both have PCIe x8 connections to the backplane).
Eric
Margus Voll
July 25, 2011 at 7:01 pmjust try like 1 and 2 for 4000 and 120 in slot 3 and dl in 4
look if it plays well. i have my 120 in slot 3 and it works well but one 4000 for now.
Margus
