Activity Forums AJA Video Systems wierdness from my kona 3 .?? constant re-seating
  • wierdness from my kona 3 .?? constant re-seating
    Posted by Thompson Coles on February 8, 2009 at 4:20 am
    ok it’s a quad core machine with 8 gb of ram. i cannot recall the processor speed.
    I’ve got a kona3 and it seems that i am constantly needing to re-seat the card. here’s the scenario, i start the day about the same. get the machine up and running, (Kona shows bars when not used) then launch FCP.
    At this point all appears perfect, the monitor activates with FCP, then plays out video and audio just fine. BUT.. here’s the kicker.
    as soon as i go to capture (this could be five minutes after startup, or five hours) The capture window is blank.
    Let me clarify that I and an engineer triple checked every single connection both to and from my bay via the router, direct connect, and the breakout box. it’s not faulty wiring, or mis routed signal.
    the only glimmer that the card is receiving a signal at all is the fact that every so often a couple scan lines show up in the lower portion of the capture window.
    the only effective method I’ve discovered to resolve the problem is to shutdown the system, disconnect the cables. then remove and re-seat the card. this has worked every time to resolve the capture issue.
    The only jarring or movement that my system gets is from this action, nothing more. so I’m having a really hard time figuring out why i have to keep re-seating the card.
    Is this an issue with the card or my computer? I want to find out before i beg Aja for a replacement Kona 3.
    Anyone else experience issues like this?
    Thompson
    Jeremy Garchow replied 17 years, 2 months ago 4 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    February 8, 2009 at 4:48 am
    What format are you capturing? Have you used an easy setup? If you use the control panel and set the control to input passthrough and play a tape, do you see picture?
    More info is needed.
    Jeremy
  • Thompson Coles
    February 8, 2009 at 3:59 pm
    yes, i’m using an easy setup. capturing dv50. and no video will pass through the card. only out of the card from the fcp timeline. sorry i thought i mentioned that i change none of the settings, only re-seat the card and everything returns to normal.
  • Jeremy Garchow
    February 8, 2009 at 4:09 pm
    You need to find out the intage of your MacPro and make sure the card is in the right PCIe slot.
    https://www.aja.com/html/support_kona_rec_sys.htm
  • Thompson Coles
    February 8, 2009 at 4:21 pm
    the cards in the right spot, if it wasn’t it wouldn’t work perfectly afterwards. I’ve checked the setup, everything is as it should be. i just cannot figure out why i need to re-seat to get the card to capture. it looks like I’ll be calling Aja tomorrow.
  • Jeremy Garchow
    February 8, 2009 at 4:50 pm
    [thompson coles] “the cards in the right spot, if it wasn’t it wouldn’t work perfectly afterwards.”
    That’s not necessarily true. Your card couls be bad, but I suspect a config issue. It’s different depeding on ehich Mac you have, and if you have an ‘older’ MacPro you need to go into the PCIe config utitlity and make sure you setup the lanes properly.
    Jeremy
  • Thompson Coles
    February 8, 2009 at 5:11 pm
    how many lanes does it require, I’ve given it 8 lanes, the card sits in slot 2. As far as I’ve read the card is as it should be. I’ve trouble shot this card up and down and i haven’t discovered a major issue with the installation, but I’m open to it. have i installed it incorrectly?
  • Jeremy Garchow
    February 8, 2009 at 5:43 pm
    Okay, just for the simple fact that you can in fact assign lanes, I would think that you have an older (i.e. Pre2008) MacPro. That’s what I have and it works great.
    You need to put the card in slot3 and then setup your PCIe config to option number 2:
    https://www.aja.com/html/support_xena_boards/exp_large.htm
    Again, you need to read this page carefully about how to configure a Pre2008 MacPro
    https://www.aja.com/html/support_kona_rec_sys.htm#
    Jeremy
  • Thompson Coles
    February 8, 2009 at 5:56 pm
    thanks ill replace the card to slot 3, and reconfigure the slot. I had been given advice to set it up differently. Thanks for the correction.
  • Bob Zelin
    February 8, 2009 at 7:42 pm
    Jeremy is correct (Jeremy is always correcT) – put the card into slot 3, and TRASH YOUR FCP PREFERENCES. The card should be set for x4 lanes. So should your storage card that may be in slot 4.
    Bob Zelin
  • Gary Adcock
    February 9, 2009 at 2:47 pm
    [Jeremy Garchow] “[thompson coles] “the cards in the right spot, if it wasn’t it wouldn’t work perfectly afterwards.”
    That’s not necessarily true. Your card couls be bad, but I suspect a config issue.”
    I have only seen this once before as a hardware problem.
    I suspect a logic board issue, you could have a partial connection internally on one of your slots.
    we would like
    QT versions
    Kona driver and Firmware versions (My second guess)
    Machine spec.
    RAM slot and type order too.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
