Activity › Forums › Apple Final Cut Pro › Why can’t I move 2 clips?
  • Eric Santiago
    October 4, 2018 at 7:07 pm
    I take it they are Connected so they should move.
    How about if you remove it from the Storyline then move?
    Or use the Position “P” tool.
  • Xavier Paredes
    October 4, 2018 at 8:42 pm
    Using the position tool (P shortcut) doesn’t work either!
    Xavier
  • Jeremy Garchow
    October 4, 2018 at 8:54 pm
    Looks like you are selecting the clips within the right secondary as well as the secondary itself. You need to select just the shelf and not the clips (and transitions).
    I hope Apple fixes the way this works because it can be rather annoying.
  • Xavier Paredes
    October 4, 2018 at 8:56 pm
    In the video I uploaded in my original post; am I not selecting the shelf?
    Xavier
  • Jeremy Garchow
    October 4, 2018 at 9:11 pm
    It looks like, it, but look at how the clip and the transitions are selected in that one, and not in the one on the left.
    Maybe try zoom in a little before you select.
  • Xavier Paredes
    October 4, 2018 at 10:40 pm
    Yes, I noticed that the transitions of one of the clips are selected but the ones for the other one aren’t. I can’t get FCP to select all transitions for both clips.
    I tried everything I can think of. No matter what I do, it doesn’t work.
    Anyone else knows if this is a bug. It’s really silly that FCP can’t do something so basic.
    Xavier
  • Jeremy Garchow
    October 4, 2018 at 11:18 pm
    It’s possible. I’d suggest zooming in a little, or adjusting the size of the clips.
    Also, a preferences trash won’t hurt, either.
    Jeremy
  • Jeremy Garchow
    Or try moving the left one over a little bit, and then selecting the shelves.
  • Xavier Paredes
    October 4, 2018 at 11:27 pm
    I tried zooming in.
    I also tried separating them.
    Nothing works. Really strange.
    Xavier
  • Jeremy Garchow
    October 5, 2018 at 12:44 am
    Trash prefs yet?
    Quit FCPX, hold down option-command and launch FCPX.
Page 1 of 4
