Activity › Forums › Adobe Premiere Pro › Why are my exports ugly?
  • Why are my exports ugly?
    Posted by Brandon Eckert on August 23, 2008 at 12:53 am
    I have an aiptek a-hd+ 1080P camera. The video I just made with the camera is 720P @ 60FPS…and saves as a quicktime movie. What do I have to do in Premiere CS3 to have it export in the same quality I imported it in? I have tried all the settings and I either get a smaller than original frame size, or a very ugly quality.
    Brandon Eckert replied 18 years, 1 month ago 4 Members · 27 Replies
  • 27 Replies
  • David Dobson
    August 23, 2008 at 3:56 am
    What are your project settings?
    Premier Pro doesn’t have a preset for H.264 Quicktimes.
    You might try using one of the XDCAM or DCVProHD presets.
    If you import the footage into a NTSC projects – it will downconvert the footage to DV and if you try to blow that up to HD it will look ugly.
    But this is all guessing without knowing more about what you did.
    Interesting camera though.
  • Brandon Eckert
    August 23, 2008 at 5:57 pm
    I am kind of new to premiere but this is my current settings:
    General
    Editing mode: Desktop
    Timebase: 60.00 fps
    Video Settings
    Frame size: 1080h 720v (1.200)
    Frame rate: 60.00 frames/second
    Pixel Aspect Ratio: D1/DV NTSC Widescreen 16:9 (1.2)
    Fields: No Fields (Progressive Scan)
    Audio Settings
    Sample rate: 48000 samples/second
    Capture Format
    DV Capture
    Video Rendering
    Maximum Bit Depth: Off
    Preview File Format: Video for Windows
    Compressor: None
    Color depth: Millions of colors
    Default Sequence
    Total video tracks: 3
    Master track type: Stereo
    Mono tracks: 0
    Stereo tracks: 3
    5.1 tracks: 0
    Submix mono tracks: 0
    Submix stereo tracks: 0
    Submix 5.1 tracks: 0
    I found that if I export using adobe media encoder…choose mpeg2…if I choose 5 quality, 1080×720, and fps of 60….that the video quality looks good…but after about 20 seconds the video gets choppy.
  • Jon Barrie
    August 24, 2008 at 4:56 am
    General
    Timebase: 60.00 fps
    Video Settings
    Audio Settings
    Capture Format
    DV Capture
    Why aren’t you using a preset? HDV NTSC 60i or DV NTSC 29.97fps
    Why is your time base 60p, r u sure it recorded in 60P? I doubt the Canon camera can do that (can do 30p – kinda).
    What is with the settings for frame size? 1080×720. never heard of it. 1280×720 is considered 720p HD/HDV. 1920×1080 for FullHD in either interlaced or progressive. HDV is 1440×1080 (anamorphic) widescreen and actually always interlaced (even in progressive it embedded in the interlacing). The PAR of 1.2 is only for DV NTSC not HD or HDV.
    Capture format is DV? Did you shoot HDV or DV?
    1. If you know what format you shot, use a preset based on it. The frame rate size and format (NTSC/PAL) will determine the frame size/rate/etc and should be correct.
    2. Use a preset.
    3. THANKYOU for sending us the project details you have no idea how many people just say my export looks weird without sending the project specs.
    – Jon Barrie 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Brandon Eckert
    August 24, 2008 at 2:13 pm
    My camera says it will shoot 1080P @ 30FPS….and 720P @ 60FPS. In premiere, top left hand corner it says:
    Movie: 1280×720(1.0) 59.96FPS
    So wouldn’t that be what the movie I imported was shot in? I just tried using the preset for “HDV 720P”…and it only allows for 29.97FPS….and as before when I export to mpeg2…the first couple seconds look/sound great…then I get a lot of skipping.
  • Brandon Eckert
    August 25, 2008 at 12:41 am
    I just did some testing in after effects CS3…and if I export as quicktime…use H.264 compression…my video exports perfectly…great quality…no skipping…but when I do the same thing in premiere cs3…I get the weird stuff mentioned above…anyone know? I just tried using the HDV 720P…and I get the same results as above.
  • Jon Barrie
    August 25, 2008 at 4:09 am
    If it start out ok and proressively gets worse I’d say its a frames per second issue. If it doesn’t match its start out ok and gets worse as time goes on. You need to be certain the 720 footage is actually running at 60p. The reviews out there say this can go upto 60p. Means it might not actually be at that mode.
    As much as this is annoying to hear, but this camera is far from professinal. I’d recommend you doulbe check the properties of the mov files in QT. then make a new project, have the same fps, frame size and when you export it make sure the properties of the export are correct too.
    If it plays back fine in the timeline, but gets bad on the way out (export) the properties in the export settings are not matching.
    – Jon 🙂
  • Brandon Eckert
    August 25, 2008 at 6:36 am
    Yes, it progressivly gets worse with the choppiness. Here is the QT information for the original mov:
    Format: H.264, 1280 x 720, Millions, AAC, Stereo, 48.000 kHz
    Movie FPS: 59.94
    Playing FPS: 59.94
    Data Size 549.81 MB
    Data Rate: 5.98 mbits/sec
    Normal Size: 1280 x 720
  • Jon Barrie
    August 25, 2008 at 10:25 am
    IF the fps is 59.94 on the clip then that is exactly what it needs to playback properly in the timeline.
    60fps is not 59.94
    59.96 is not 59.94
    that tiny amount difference is what adds up over time to a poorly synced up video by the end.
    The export needs to be the same too. 59.94
    Try using the SONY EX preset 720p you’ll see the 60p that uses the 59.94 fps for clips.
    Start there…
    – Jon 😉
  • Brandon Eckert
    August 25, 2008 at 11:44 am
    I will try those presets when I get home. Do you know which export I should use that will keep the quality? I noticed that even though my film is using quicktime H.264 @ 59.94 FPS…the most I can export as quicktime H.264 is 30FPS.
  • Brandon Eckert
    August 25, 2008 at 5:04 pm
    “Try using the SONY EX preset 720p you’ll see the 60p that uses the 59.94 fps for clips. ”
    Stupid question… just looked for the import presets…and don’t see anything that says SONY EX?
Page 1 of 3
