Activity › Forums › Adobe Premiere Pro › Why are my exports ugly?
  • Mike Velte
    August 25, 2008 at 6:07 pm
    [Brandon Eckert] “and don’t see anything that says SONY EX?”
    Update CS3 to 3.2 and the EX Project presets should be at the bottom of the Projects presets.
  • Brandon Eckert
    August 26, 2008 at 2:48 am
    Alright, I just tried the sony 720p preset you said, and also tried exporting via File > Export > Adobe Media Encoder.
    I selected Quicktime > H.624. Settings wise I selected:
    Frame Size: 1280×720
    Quality: 100
    FPS: 59.94
    Field Order: None Progressive
    Pixel Aspect Ratio: Square Pixels (1,0)
    Bit Depth: 24-bit (wont allow me to change)
    Bitrate: 5.24
    I still get bad quality compared to my original. I have bad pixelation of the video even at 100 quality.
  • Jon Barrie
    August 26, 2008 at 7:31 am
    Can you post the video (a small part of it) on a host site? I can only look at it to tell you whats happening.
    – Jon Barrie 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Mike Velte
    August 26, 2008 at 10:47 am
    5 mbps seems awful low for HD…try 10, 15 and 20 mbps.
  • Brandon Eckert
    August 26, 2008 at 11:21 am
    Jon Barrie: I will do this when I go home for lunch today at noon.
    Mike Velte: The original video is around 5.23 I believe.
  • Mike Velte
    August 26, 2008 at 12:16 pm
    AVCHD typically is compressed to about 15- 20 mbps. HDV about 25 mbps. Your little camera compresses to only 5? Is ther no other options in the camera?
    I suspect that is the root of your problem…decompressing during editing and recompressing again already very highly compressed files.
    I would still try to export at 15 mbps.
  • Brandon Eckert
    August 26, 2008 at 12:21 pm
    To my knowledge no. The only settings I can change is if I want 1080p @ 30fps…720p @ 60 fps (59.94), or two low quality videos. The HD compression is done with H.264 on the camera.
    I guess my questioning is why does after effects export perfectly?
  • Brandon Eckert
    August 26, 2008 at 4:57 pm
    https://niveohosting.com/new_h264.mov
    For some reason it appears even though i’m telling Premiere to use 20 bit rate for example…it is doing lower?
  • Brandon Eckert
    August 26, 2008 at 7:06 pm
    Alright, here is an update guys. I just tried exporting via the File > Export > Quicktime > H.264…and I get my quality…and I get my non skipping…but the problem is my file size has increased by a ton! My original file size is around 515MB for around 14 minutes…my one minute export is around 500mb.
  • David Dobson
    August 26, 2008 at 9:22 pm
    I hate when that happens.
    You’ll have to keep fiddling with the bit rate till you get what you want.
Page 2 of 3
