Activity Forums Adobe Premiere Pro Which Renderer to select ?
  • Which Renderer to select ?
    Posted by Soumendra Jena on November 15, 2013 at 1:36 pm
    We just finished doing some premiere projects and now its time to render.
    In the render engine of PP PRO CC and Media Encoder CC, I see there are two options,
    MERCURY PLAYBACK ENGINE GPU ACCELERATION [CUDA]
    MERCURY PLAYBACK ENGINE SOFTWARE ONLY
    If I select the 1st one, it says, its not certified.
    So, I selected the 2nd one and it gets selected fine.
    I would like to know, which is better and which renders quick ?
    Why they are two options there ? Any specific job for each ?
    Gene Weglarz replied 12 years, 1 month ago 5 Members · 9 Replies
  • 9 Replies
  • Steve Brame
    November 15, 2013 at 2:36 pm
    The GPU ACCELERATION option is available only if you have a graphics card that is supported by that feature. If your graphics card isn’t one of the supported cards, you can only use the SOFTWARE ONLY option. Being able to use the GPU ACCELERATION option will greatly increase the speed in which rendering takes place, so it might me worth it to invest in a supported card.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Soumendra Jena
    November 15, 2013 at 3:08 pm
    Check my graphics card,
    https://d.pr/i/i9Lk
    I paid a huge for my graphics card, so Im sure, it should be 100% perfect.
    What do you think, Im missing ?
  • Steve Brame
    November 15, 2013 at 3:27 pm
    Here is the list of currently supported cards. The GTX 670 is not on it.
    https://www.adobe.com/products/premiere/tech-specs.html
    However, it may still work. Take a look at this…
    https://blogs.adobe.com/premierepro/2013/06/adobe-premiere-pro-cc-and-gpu-support.html
    Steve Brame
  • Soumendra Jena
    November 15, 2013 at 3:36 pm
    HOLY GOD!
    Damn, I paid so much for this graphics card. Damn damn damn.
  • Paul Neumann
    November 15, 2013 at 3:47 pm
    If it meets the minimum requirements regardless of certification you can use it.
  • Steve Brame
    November 15, 2013 at 4:01 pm
    Yes, please read the 2nd link that was in my post.
    Steve Brame
  • Soumendra Jena
    November 15, 2013 at 4:32 pm
    If I change it to CUDA and keep it selected, then the render time increases 3 times .
  • Ericbowen
    Adobe CC will allow the hardware acceleration with Nvidia cards whether it’s on the supported list or not. The message is warning now that it’s not officially supported or tested. However last I checked Media Encoder would not use the hardware MPE acceleration if it wasn’t on the supported list so we still add the cards so they are. The last Adobe update may have fixed that but I haven’t tested it yet.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Gene Weglarz
    July 24, 2014 at 2:22 pm
    You can add an NVidia CUDA card to the supported cards text file.
    Open a CMD prompt
    CD to the directory where Premiere Pro is installed.
    Run gpusniffer.exe
    Add the card name to the cuda_supported_cards.txt file. Use the name exactly as it appears in the output from gpusniffer.exe
    Geoffrey Weglarz
