Activity › Forums › Apple Final Cut Pro Legacy › which capture card best for FCP ?
  • which capture card best for FCP ?
    Posted by Rajarshi Basu on February 10, 2007 at 12:13 pm
    Im planning on making a switch from my Premiere Pro to FCP. My future projects will be mainly on DVCPro HD and HDV 1080i. This is my first big buy…
    Im planning on buying a Mac Pro. i have a few questions,
    What analog/digital capture card can i get for under 1000 dollars or less ?
    …declink extreme seems to be the most popular in this category.
    Can I watch my HD output real time in a HD ready LCD TV with the card?
    and how much RAM woukd I need to efficiently edit HD footage and do some basic 2d After Effects work ?
    Raj
    Paul Dickin replied 19 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Anders Haavie
    February 10, 2007 at 12:21 pm
    Aja or Decklink are two good brands.
    Not sure about the tv, but we have a panasonic hd lcd monitor that works great with dvcprohd. (sdi in)
    4 gig ram is ok. I find that you can work with only 2 gig, but 4 is much more smooth.
    Good luck
  • Rajarshi Basu
    February 10, 2007 at 12:29 pm
    the reason is that, since im already shelling out the money, i want a TV cum
    preview monitor…si i can watch my dvds…
  • Walter Biscardi
    February 10, 2007 at 12:45 pm
    [Rajarshi] “What analog/digital capture card can i get for under 1000 dollars or less ?
    …declink extreme seems to be the most popular in this category.”
    Decklink is your only choice when you go that low in your budget. I only recommend AJA Kona products, but if you can’t afford them, then decklink is your only choice.
    [Rajarshi] “Can I watch my HD output real time in a HD ready LCD TV with the card?”
    As long as it has component or SDI input. A consumer LCD HD screen will not be a great monitor though if you are doing a lot of color correction. A Panasonic 1700 or 2600W would be a better choice, or even a panasonic pro plasma screen.
    [Rajarshi] “and how much RAM woukd I need to efficiently edit HD footage and do some basic 2d After Effects work ?”
    RAM has no bearing on HD footage, your storage does. Any FCP system should have a minimum 4GB RAM.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Chris Poisson
    February 10, 2007 at 1:07 pm
    Walter,
    I’m not sure I read your answer to this correctly.
    My Kona LH will feed a real-time signal to ANY monitor no matter how its hooked up using Kona’s downconvert feature. True, even on my Sony 14″ SD monitor (which I bought from you) color correction is not perfect, but it’s close. At least I get through my projects, knock on wood.
  • Walter Biscardi
    February 10, 2007 at 1:19 pm
    [Chris Poisson] “Walter,
    My Kona LH will feed a real-time signal to ANY monitor no matter how its hooked up using Kona’s downconvert feature.”
    He asked about HD so to view HD he’ll need Component or SDI.
  • Chris Poisson
    February 10, 2007 at 2:53 pm
    Walter,
    Well, I’m confused, because I was talking about an HD project too. The Kona downconverts through my Beta deck to any monitor with any connector. There’s a whole thread about this back a month or so ago.
  • Rajarshi Basu
    February 10, 2007 at 4:57 pm
    thanks walter, your suggestions were really useful. Actually on second thoughts I am very much inclined towards the Adobe Production Studio, because of the dynamic link factor, but i would still go for a Mac Pro. And about the Ram, is it always better to have 6 or 8GB i figure for HD .
    thanks
    raj
  • Paul Dickin
    February 10, 2007 at 5:35 pm
    [Rajarshi] “I am very much inclined towards the Adobe Production Studio, because of the dynamic link factor”
    Hi
    Earlier this week I saw the Mac version of Premiere Pro, and Adobe’s v3 Production studio, demonstrated on a MacBook Pro.
    Only a very limited feature set was allowed to be shown, and I was interested that whilst firing up Bridge and Dynamic Link the demonstrator structured in a carefully timed drink-a-bottle-of-water break whilst the software prepared itself 😉
    No doubt by the time it ships things won’t be so sluggish, and I didn’t see anything in the demo of what Dynamic Link does that Apple’s FCP<>Motion, Shake, or Soundtrack Pro doesn’t already do with its round-trip project interchange…
    However the fact that there is now direct and equivalent competition between both suites of software is bound to be good! 🙂
    Apple will need versions new of all its Pro apps at NAB, or soon after, if it is to remain ahead of Adobe’s game…
