Activity › Forums › Apple Final Cut Pro Legacy › Where do the P2 Drivers reside…
Posted by Mark Wils on January 28, 2008 at 5:59 pm….in FCP?. I think maybe my driver is corrupt and I’d like to dump it and try to reload
Mark Wils replied 18 years, 8 months ago 3 Members · 16 Replies -
Jeremy Garchow
January 28, 2008 at 6:19 pm -
Mark Wils
January 28, 2008 at 6:22 pm….Thanks, but I mean where do they reside on my hard drive….what MAC/FCP folder(s)… and what in the world am I looking for??
Jeremy Garchow
January 28, 2008 at 6:52 pmLet’s back up a minute, what is the problem you are having?
Mark Wils
January 28, 2008 at 7:04 pm….Same problem I was having last week…
https://forums.creativecow.net/readpost/8/972098
footage is there… works fine on my MPB… but I can’t load my clips into the bins on my MacPro…. I can see them in the preview window… but I can’t load them into the bins or work with them…. I’ve done all of the suggested steps… and loaded/reloaded all software suggested in this link,
https://forums.creativecow.net/thread/8/971959
….but NOW when I try to install the P2PCCard software…. I get an “Install Failed” message. ….. so….I’ve exhausted most of my “computer” knowledge and I’ve about had it with this thing….
John Pale
January 28, 2008 at 7:27 pm[Mark Wils] “….but NOW when I try to install the P2PCCard software…. I get an “Install Failed” message. ….. so….I’ve exhausted most of my “computer” knowledge and I’ve about had it with this thing….
“Sorry if you tried this already (I didnt read every post in the threads you cited), but a failed installation often is a sign of bad file permissions….have you repaired permissions on your hard drive using Disk Utility. Again, apologies, if you already tried that.
Mark Wils
January 28, 2008 at 7:54 pm…please, don’t apologize for anything, I can use all the help I can get. Yup, did the Permissions thing last week…
Jeremy Garchow
January 28, 2008 at 7:57 pmAlright, going out a a limb here.
Open up disk utility and select the drive you are trying to install to. On the bottom of the disk utility window, there’s a bunch of info, what does it say for “Partition Scheme”?
Mark Wils
January 28, 2008 at 8:10 pm…here’s what I’ve got…
Partition Map Scheme : GUID Partition Table
…also….after I repair permissions I get this stuff… means ZERO to me… but it doesn’t look good….
Repairing permissions for “Macintosh HD”
Permissions differ on “sbin/restore”, should be -r-xr-xr-x , they are -r-sr-sr-x .
Warning: SUID file “sbin/restore” has been modified and will not be repaired.
Permissions differ on “sbin/rrestore”, should be -r-xr-xr-x , they are -r-sr-sr-x .
Warning: SUID file “sbin/rrestore” has been modified and will not be repaired.
Permissions differ on “sbin/launchd”, should be -rwxr-xr-x , they are -rwsr-xr-x .
Warning: SUID file “sbin/launchd” has been modified and will not be repaired.
Warning: SUID file “System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent” has been modified and will not be repaired.
Group differs on “usr/bin/lppasswd”, should be 0, group is 26.
Permissions differ on “usr/bin/lppasswd”, should be -rwxr-xr-x , they are -rwsr-xr-x .
Warning: SUID file “usr/bin/lppasswd” has been modified and will not be repaired.
Permissions differ on “sbin/mount_smbfs”, should be -r-xr-xr-x , they are -r-sr-xr-x .
Warning: SUID file “sbin/mount_smbfs” has been modified and will not be repaired.
Permissions differ on “usr/bin/smbutil”, should be -r-xr-xr-x , they are -r-sr-xr-x .
Warning: SUID file “usr/bin/smbutil” has been modified and will not be repaired.Permissions repair complete
Jeremy Garchow
January 28, 2008 at 8:15 pmALright, they creating a new user with your mac with all admin privileges and reinstall P2.
Jeremy
