Activity Forums VEGAS Pro Where can I find Boris FX in SV pro 9?
  • Where can I find Boris FX in SV pro 9?
    Posted by Petroi Teodora on June 17, 2011 at 12:54 pm
    I installed 2 Boris effects, but I can’t find them in SV…
    Also, for those who use these effects, are they worth it? I heard they are even better than New Blue.
    John Rofrano replied 13 years ago 5 Members · 13 Replies
  • 13 Replies
  • John Rofrano
    June 17, 2011 at 5:37 pm
    [Petroi Teodora] “I installed 2 Boris effects, but I can’t find them in SV…”
    Which 2 effects? If they are OFX based effects they won’t work in Vegas Pro 9.0. You’ll need to upgrade to Vegas Pro 10.0 to use any of the new OFX effects from Boris, GenArt’s, NewBlue, etc.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Petroi Teodora
    June 18, 2011 at 7:29 am
    Yeah, I think that’s the problem, that I have pro 9, and not 10.
    In order to install 10, do I need to uninstall 9 previously? And will I lose the installed New Blue FXs and colorings?
  • Stewart Bourke
    June 18, 2011 at 3:03 pm
    Petroi,
    You can install all the Sony products side by side – you do not need to uninstall one to upgrade to another version.
  • John Rofrano
    June 18, 2011 at 6:45 pm
    [Petroi Teodora] “In order to install 10, do I need to uninstall 9 previously? “
    No, you can have as many versions of Vegas installed as you’d like. I have both 9 and 10 in both the 32 and 64 bit versions and all is working fine.
    ~jr
  • Petroi Teodora
    June 18, 2011 at 6:53 pm
    Thank you very much!
  • Petroi Teodora
    June 19, 2011 at 1:20 pm
    I can’t install SV Pro 10 because I don’t have Service Pack 3 (I use Windows XP). I activated the updates from Internet Explorer, should this Pack 3 be installed sometime soon?
  • Mike Kujbida
    June 19, 2011 at 2:50 pm
    [Petroi Teodora] “should this Pack 3 be installed sometime soon?”
    If you want to run Pro 10, the answer is yes.
    Be sure to set a restore point before doing the upgrade just in case something goes wrong.
    Even better is a backup of your C drive.
  • Petroi Teodora
    June 20, 2011 at 6:54 am
    Is been 2 updates already (each time, the computer restarts itself), but I still can’t install pro 10. >.< Is driving me mad.
  • John Rofrano
    June 21, 2011 at 11:02 am
    [Petroi Teodora] “Is been 2 updates already (each time, the computer restarts itself), but I still can’t install pro 10. >.< Is driving me mad.”
    You may need to download SP3 manually. This is very old now and XP is no longer supported by Microsoft so you are really on your own to get this to work. I thought there was a manual download of SP3 somewhere on the Microsoft site that you can use. Try this:
    Windows XP Service Pack 3 Network Installation Package for IT Professionals and Developers
    ~jr
  • Petroi Teodora
    June 22, 2011 at 2:28 pm
    I found it here: https://support.microsoft.com/kb/322389#toA Do u think it’s safe to install it?
