Activity Forums Apple Final Cut Pro Legacy When is Digital not Digital? Firewire or SDI?
  • When is Digital not Digital? Firewire or SDI?
    Posted by Andy Taplin on January 18, 2006 at 10:43 am
    I’m sure this has been discussed before but I feel it’s SO important to understand that it needs bringing up every now and again.
    Is there a provable, definitive answer to the question about which input to an NLE like FCP (via a card of your choice) is better – Firewire or SDI?
    Looking around the Net there is a lot of argument and contradiction about which is best as an input/output workflow.People seem to disagree even on whether DV transferred over Firewire is a clone or is there compression/decompression going on when it ends up as a QuickTime file?
    Is SDI adding errors to the data or compressing it in any way? Why should you pay more for SDI cards?
    When you copy a file from computer to computer digitally (ones ans zeros to ones and zeros) the two are the same i.e. clones. This would appear to not be the case with DV? So when is digital not digital? And how does all this affect the move to HD?
    I hope this gets a debate going with the tech heads who can sort it out one and for all!
    Graeme Nattress replied 20 years, 8 months ago 12 Members · 36 Replies
  • 36 Replies
  • Shane Ross
    January 18, 2006 at 10:53 am
    IF YOU ARE WORKING WITH DV ONLY…
    Capture via firewire is lossless. Capture via SDI adds compression. Slight compression, but compression. DV natively is compressed 5:1
    BUT…the BIG advantage of SDI at the uncompressed codecs is that your graphics, titles, stills all benefit from the 8 or 10 bit uncompressed rate. Thus while your tape footage is still compressed 5:1, your graphics, stills and text isn’t…and will be far sharper.
    PLUS…you benefit tons for being able to color correct and add filters at uncompressed 4:2:2, as opposed to DV 4:1:1.
    Will you notice the difference in the Firewire vs SDI capture on the tape footage? Doubtful. Will you notice a difference in your text and graphics…most definately.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Walter Biscardi
    January 18, 2006 at 11:24 am
    [Andy Taplin] “Is there a provable, definitive answer to the question about which input to an NLE like FCP (via a card of your choice) is better – Firewire or SDI?”
    What format are you talking about?
    For DV and DVCPro HD there’s no reason to come in SDI, it’s an identical capture to bringing in the footage via Firewire. I work with DVCPro HD all day long and we bring it in and master out via Firewire.
    For Uncompressed SD and HD, then you need to come in via SDI to work in those formats (or component if your system supports that). Firewire doesn’t support uncompressed HD, though it will support uncompressed SD with the AJA Io series.
    [Andy Taplin] “This would appear to not be the case with DV? So when is digital not digital? And how does all this affect the move to HD?”
    I don’t understand this “when is digital not digital?” Firewire and SDI are both digital formats. Regardless of which input you’re using, you’re working in digital. Digital is not digital when you work in an analog format such as component, composite or S-Video.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Andy Taplin
    January 18, 2006 at 11:54 am
    Thanks Shane
    The main reason for the post is that currently I’m working with DVCAM (PAL) on Media 100 but will be moving to FCP this year. In M100 I’m capturing via Firewire and this then gets converted to M100’s MJPEG codec. Results are good but it’s still converting from DV to MJPEG which I would imagine adds errors.
    Are you saying you can captre DV or DVCVAM into FCP via Firewire (which is compressed at 5:1 on the tape) and then uncompress it to a new uncompressed codec? This is no doubt a stupid question but where does the extra information to turn it from 5:1 to 1:1 come from?
    Andy
  • Walter Biscardi
    January 18, 2006 at 11:57 am
    [Andy Taplin] “Are you saying you can captre DV or DVCVAM into FCP via Firewire (which is compressed at 5:1 on the tape) and then uncompress it to a new uncompressed codec? This is no doubt a stupid question but where does the extra information to turn it from 5:1 to 1:1 come from?”
    There is no extra information to turn it into 1:1. 5:1 compressed stays 5:1 compressed no matter how you bring it in. If you come in via Uncompressed SD, the footage is still going to be 5:1 compressed in the camera and you just have a much larger file in FCP.
    Capturing DV / DVCAM via Firewire is considered a “lossless” capture. That is FCP adds no additional compression to the footage and original quality is maintained.
  • Andy Taplin
    January 18, 2006 at 12:06 pm
    Hi Walter
    Using DVCAM you’re saying there is no difference between Firewire and SDI? Maybe it looks the same but surely there are technical differences with compression and suitability for various post work – even with SD? That’s why I
  • Mike Smith
    January 18, 2006 at 12:11 pm
    Hi Walter
    I guess the plus of going to uncompressed comes in the extra colour space for grading / timing, and for effects and graphics work.
    Of course the (DVCAM) camera footage gains no extra info in going uncompressed (via SDI if you have a DVCAM deck with SDI out, or via software conversion), but for broadcast the additional colour information will allow better results when the final color correction, effects and graphics have been added.
    But you add a lot of extra data handling, storage requirement and system load for your gains. So if your output requirements are corporate / DVD / vhs, as Andy’s seem to be from his website, then I guess those costs may outweigh the benefits.
  • Andy Taplin
    January 18, 2006 at 12:12 pm
    So if Firewire capture is lossless why capture SD via SDI as some people are suggesting?
  • Walter Biscardi
    January 18, 2006 at 12:14 pm
    [Andy Taplin] “Using DVCAM you’re saying there is no difference between Firewire and SDI?”
    Nope, capture quality will be exactly the same.
    [Andy Taplin] “Maybe it looks the same but surely there are technical differences with compression and suitability for various post work – even with SD? That’s why I
  • Walter Biscardi
    January 18, 2006 at 12:16 pm
    [Andy Taplin] “So if Firewire capture is lossless why capture SD via SDI as some people are suggesting?”
    If you want to edit in an uncompressed 720×486 timeline, then you come in via SDI. Other than that, there’s no reason to do this.
  • Andy Taplin
    January 18, 2006 at 12:31 pm
    Thanks for the advice guys
    Most of my stuff involves some working in AFX (or maybe now Motion) as well as the NLE and then importing AFX renders back into the NLE. I tend to produce DVD masters nothing goes out on tape anymore.
    Would you therefore reccommend capturing via SDI uncompressed to get better quality after rendering in AFX? What codec would you render out with (Sheer?) and lastly, how much bigger are the files capturing using SDI uncompressed compared to Firewire DV – which I guess comes into FCP at 3.6MB per sec?
    many thanks
    Andy
Page 1 of 4
