Activity Forums Apple Final Cut Pro Legacy What reality is the audio pitch effect based on??? and how it relates to speed?
  • What reality is the audio pitch effect based on??? and how it relates to speed?
    Posted by Bob Flood on February 23, 2006 at 7:34 pm
    Hey yall
    I have to speed up some clips in FCP and i want to downpitch the sound
    (love the way it does sound w pix!)
    Whats the ryhyme or reason to translate the pitch values to percent of speed.
    I guess its a musical scale, but i cant seem to see any correlation?
    thanx in advance
    bee eph
    Bob Flood
    Greer & Associates, Inc.
    Bob Flood replied 20 years, 7 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    February 23, 2006 at 9:01 pm
    This should take you into the newest addition to the FCP family. Soundtrack Pro. You can speed up or slow down sound without adjusting pitch. What you would need to do is export the normal sound, and then adjust the length in STPro. This will work up until a point and then the audio will just sound kinda funky. Make sense?
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Bob Flood
    February 24, 2006 at 4:28 am
    yES! thanx!
    however
    I actually did a search on the internet for pitch and speed and got the following info:
    the FCP AUPITCH Plugin changes pitch in Cents, which are hundredths of a semitone, which is equal to 6%. So a 1% change in pitch is equal to 16.7 cents.
    based on this i had a clip at 112%, which is equal to 12 x 16.7 or 200.4, and sure enough, a downpitch setting of 200 or -200 makes the voices sound correct!
    I love the internet!
    bee eph
    Bob Flood
