Activity › Forums › Adobe Premiere Pro › What exactly is Media Management? (Premiere is lacking this….people say)
Larry Sherwood replied 20 years, 7 months ago 10 Members · 28 Replies
David Cherniack
January 17, 2006 at 10:13 pm[Mike Cohen] “What if you make a sub-clip out of your selects from the nested sequences before putting them into the edit you are buidling. Can you even do that? If so, then can you delete the original nested sequence without ruining the subclips? Doesn’t sound very promising.”
I’m not sure if PPro 2 allows making sub-clips of sub-timelines. Besides, the edit has been mostly built. The only way around ingesting 33 hours would appear to be replacing the subtimlines with source and I can’t see any easy way to do it that doesn’t involve multiple tedious steps. Easier to reingest.
David
AllinOneFilms.com -
David Cherniack
January 17, 2006 at 10:16 pm[Tim Kolb] “It sounds like the Axio probably solved most of his issue when it allowed him to work with HDV directly?”
For future projects, yes….It just means sticking with an online workflow.
David
AllinOneFilms.com -
Agent2a03
January 18, 2006 at 12:23 am“the ability to simply do a recapture based on a Sequence allowing users to “Uprez” their footage quickly and easily”
So can Premiere Pro 2.0 do this now? I know it wasn’t possible with 1.5 but I’m hoping 2.0 can do it…. Also does anyone know where I can find screenshots or more info on the new Media Manager? I can’t seem to find much….Thanks
Ken Adolph
January 18, 2006 at 1:12 amThis “double system” is a problem with Premiere. The only way to sync the clips and keep them synced is the way that David has indicated unless someone has a better idea.
The other factor is that the files recorded with the Soound Design or Fostex are recorded in Broadcast Wave format which means that it includes the TC in the metadata. Unless things have changed in PPro2 or Audition2 both these applications are without BWF support. Typically the TC is jammed from the audio recorder to the camera so they are both showing the same TC. This makes it easy to sync but you can’t lock the audio to the picture. If you could then the trimming of projects would work.
This is very important in documentary and feature work and Axio is not going to help except if you capture all your footage at on-line resolution in the first place.Ken Adolph
Media Group
Editor/Post Supervisor
https://www.mg.ca -
Larry Sherwood
January 18, 2006 at 2:58 amIt shows a complete lack of understanding of the software/formats/ and offline/online workflow specially when it comes to HDV and timecode! PPro could easily do what you ask had you set up the project properly to begin with.
I had hoped you would provide us with this “easy” solution to approaching this task as this is a common need for most of us who work with double-system sound. As Tim accurately points out, one of the “shortcomings” of HDV is audio quality and it would really be great to find the proper project setup you mentioned, please don’t end this very important and informative thread in dead silence. . .
Inquiring minds want to knowLS
Lance Bachelder
January 18, 2006 at 5:45 amTim,
You’re so gracious and the consummate host – I should have never opened my mouth on this one. Is there a logical workflow – yes – but I’m done, I’ve been watching Simon Cowell for too long. I apologize to Ron, Kathlyn and everyone else on this forum for wasting valuable forum space.
Lance Bachelder
Southern California
Cow Forum Host- Magic BulletApple Dual 2Ghz G5 ATIx800, 2.5GB RAM, OSX Tiger FCP Studio
Intel P4, 2GB RAM, PNY 6600GT XP Pro – Vegas 6 Studio -
Tim Kolb
January 18, 2006 at 6:26 am[Lance Bachelder] “I apologize to Ron, Kathlyn and everyone else on this forum for wasting valuable forum space”
It isn’t wasted if you can help somebody…if you do have an alternative workflow, I’m sure it would benefit more than just David and Larry…I haven’t gone there yet, but I can’t say that dual-system sound isn’t going to come up at SOME point this year…
…I’ve put up more than a couple posts on the Cow that I wish I could take back…heat of the moment…some other external reason to be in a bad mood…it happens. If you really do have an option…please, offer it.
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Larry Sherwood
January 19, 2006 at 2:17 amIs there a logical workflow – yes – but I’m done, I’ve been watching Simon Cowell for too long.
Lance, I don’t get it. I read your bio under your Forum Leader picture, you’re a forum leader, you get glowing reviews from the Boomers, you join a thread and tell us – “I know the answer, I’m just not in the mood to share”
Not exemplory behavior especially for a leader on the COW. I hope you re-consider. . .LS
