Activity Forums VEGAS Pro What are the best export settings for Youtube and Vimeo?
  • What are the best export settings for Youtube and Vimeo?
    Posted by Petr Berger on February 11, 2011 at 8:36 pm
    What are the best export settings for Youtube and Vimeo in Sony Vegas 10? Mainconcept AVC or Sony AVC or something else?
    John Rofrano replied 12 years, 10 months ago 10 Members · 26 Replies
  • 26 Replies
  • Danny Hays
    February 12, 2011 at 4:58 am
    They’re both going to recompress it so to bypass a comprssion render, send the best quality video you can make to fit in the file file size and lenght you can. Other wise use Sony AVC, internet in the same resoulution as your source footage.
  • Petr Berger
    February 12, 2011 at 4:17 pm
    i see, but youtube and vimeo recommends h264 codec in mp4 format…
    is there some difference between manconcept AVC and sony AVC?
  • Danny Hays
    February 12, 2011 at 5:31 pm
    Vegas doesn’t render to H264. I just rendered a sample as Sony AVC mp4 and main concept AVC mp4, both 1920×1080 10mbps bitrate and the main had sync isues where the sony played fine. both were almost the same in file size. If you download a video from You Tube, the higher quality ones are mp4. But even if you upload an mp4 they will still re-encode it. I believe they prefer mp4 since the quality can be good and the file size small, which makes for faster uploads.
    Bottom line is the better quality you upload, the better your video will look.
  • John Rofrano
    February 12, 2011 at 9:54 pm
    [Danny Hays] “Vegas doesn’t render to H264”
    I think you mean that Vegas can’t render h.264 to a QuickTime MOV file but the Sony AVC and MainConcept AVC codecs are both AVC/H.264 so vegas absolutely does render to h.264 as an MP4 file.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Rofrano
    February 12, 2011 at 10:02 pm
    [Petr Berger] “is there some difference between manconcept AVC and sony AVC?”
    The MainConcept AVC codec is capable of two pass VBR encoding and so it’s probably better at very low bit-rates. It only supports Baseline and Main profile. The Sony AVC codec is CBR only, but it supports Baseline, Main, and High profiles (high profile is required for AVCHD).
    Both are h.264 and you can use either for YouTube but the Sony AVC encoder has YouTube templates (they all start with “Internet xxx”) so you might as well use them. I find the Sony AVC Internet 1280×720-30p template does a real nice job when uploaded to YouTube.
    ~jr
  • Danny Hays
    February 12, 2011 at 10:54 pm
    I didn’t know that about Vegas making H264. Thanks John.
  • Scott Mitchell
    April 21, 2011 at 11:21 pm
    When I use MediaInfo on a Sony AVC file, it shows it as “Variable” instead of “Constant.”
    To make things worse, while the “bit rate” is close to what I set for the render (I set 4,000 Kbps and Media info shows 3,367 Kbps), the “Maximum bit rate” is large (16Mbps).
    Anyone else getting this result?
  • Scott Mitchell
    April 21, 2011 at 11:40 pm
    In fact, check this out. Using Sony AVC. Selected Main Profile and Constant 4,000,000 bps. Here is my MediaInfo.
    It notes High Profile (High@L4.0) and the bitrate is Variable.
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=2, N=15
    Muxing mode : Container profile=Main@3.1
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 26s 26ms
    Bit rate mode : Variable
    Bit rate : 3 406 Kbps
    Maximum bit rate : 16.0 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.123
    Stream size : 10.6 MiB (93%)
    Language : English
    Encoded date : UTC 2011-04-21 23:33:52
    Tagged date : UTC 2011-04-21 23:33:52
  • John Rofrano
    April 22, 2011 at 11:23 am
    [Scott Mitchell] “When I use MediaInfo on a Sony AVC file, it shows it as “Variable” instead of “Constant.” “
    That’s very interesting and I did a few test renders to prove that it’s true. I performed two render tests on both MainConcept AVC and Sony AVC and Sony AVC is definitely using VBR.
    So here’s what I did: I rendered 30 seconds of black and 30 seconds of a test pattern through MainConcept AVC as CBR and both files were the exact same size as you would expect because CBR uses the same amount of bits for every frame regardless of whether you need them or not.
    I then preformed the same test with Sony AVC and the two files were extremely different sizes (500KB vs 4,000KB). This proves that Sony AVC is using a variable bit-rate just like MediaInfo is reporting.
    Of course, nowhere on the Sony GUI does it actually say that it’s using CBR… we all just assumed that since we can only set one bit-rate that it was CBR, but as you have seen, the bit-rate is really the average for a VBR with a max of 16Mbps.
    ~jr
  • John Sieber
    September 5, 2012 at 8:23 pm
    Jumping in a little late here, but I have a further question about the bitrates used…
    I’ve been using the Sony AVC render, with the internet 1080p template – it’s default bitrate is 16Mbps… Are you saying that is the max bitrate, but Vegas will encode at a variable rate? I’ve been using this setting and have what seem like overly huge resultant files. With the intent of upload to youtube/vimeo, is that setting overkill? And for archiving – would that default rate be a good choice to archive the work?
    http://www.johnsieber.com
Page 1 of 3
