Activity › Forums › Adobe After Effects › watercolor look
watercolor look
Posted by Steven Tader on July 11, 2006 at 2:26 pmdoes anyone have any tips or tricks when it comes to pulling off a watercolor sort of look. i have several mattes that i can use to bring elements onto the screen, but i am having a hard time getting the images to blend correctly. any advice or recommendations would be appreciated. Thanks!
Michael Szalapski replied 20 years, 2 months ago 5 Members · 5 Replies -
Justin Productions
July 11, 2006 at 2:54 pmDepending on wich version of After Effects you are using, if you have AE 6.5 (or higher), go into Effect > Adjust > Photo Filter. Then choose Cooling filters and adjust the parameters to your needs.
Plenty of other ways to do this, but probably the fastest and easiest.
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.5 Professional -
Ron Lindeboom
July 11, 2006 at 3:53 pmOne of the favorite ways that I have used to do this, is to create a few layers of the exact same footage in the exact same positions on the timeline. Then, adjust opacity of the layers and add watercolor filters, etc., to one layer but one another and use blend modes to affect the image. Using this technique, you can soften the edges of your image without totally losing them to the watercolor effect, and you can also add just enough watercolor effect that you don’t end up with the canned look that you often see used when people use the plug-ins on a single layer image.
Sometimes, I will desaturate one layer, add a charcoal-like look to it, soften its opacity just enough to blend it into the image, add a bit of watercolor to the image layer above it (which is the same image, remember?), adjust the level of opacity on this layer and also try various blend modes to taste.
The bottom layer is my basic untouched version of the image and so the “stacked” and effected versions of the image atop it, affect the image and change its look.
Using things like this, you won’t end up with that “Hey, I used re:Vision FX’s Van Gogh or one of DigiEffects’ paint plug-ins” look.
Best regards,
Ron Lindeboom
Lessevolvedman
July 11, 2006 at 4:03 pmNot quite watercolour but kinda close and looks pretty cool..
//lessevolvedman
http://www.lessevolvedman.com.au -
Ron Lindeboom
July 11, 2006 at 4:26 pmAnother thing you can do is try using Posterize Color on your main or even subsequent image layer. See how it affects your image.
You can get some very cool looking effects using it.
Best regards,
Ron Lindeboom
Michael Szalapski
July 13, 2006 at 3:59 amAnd there’s always the ever popular duplicate footage, blur, blend mode=darken.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
