Warning message
Posted by Rick Bushell on January 22, 2014 at 6:48 amI’ve had problems with retrieving events from my ‘Sony projects’ file. I lost (or so I think) almost an entire event yesterday and decided to devide and work on the project in smaller events and then nest them as the entire project was always crashing. I assumed this was due to being too large with a lot happening. Now, I keep getting this warning message: An error occurred during the current operation.
Some streams in the media file could not be opened.
I’m at a complete loss here.. Help please
RickRick Bushell replied 12 years, 8 months ago 4 Members · 12 Replies -
Graham Bernard
January 22, 2014 at 7:55 amCheck your free space on ALL your drives.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Rick Bushell
January 22, 2014 at 8:09 amThanks Graham, but both drives have plenty of space left. On the computer, 1.33 tb available and ext drive 800 gb. ?
Rick
Graham Bernard
January 22, 2014 at 12:39 pmCan you load the VEG at all?
G
Rick Bushell
January 22, 2014 at 7:56 pmI think I loaded the bak file and then it only partially loaded, eg, Some footage loads and the audio track is there but with no audio.
Graham Bernard
January 22, 2014 at 9:22 pmHmmm… See how much you can salvage from the BAK. Also COPY that BAK and call it something like SalvagingVeg 1a.veg – at least you can then retain the BAK intact.
Then I’d go through each and every Event and check to see if any of them had been MIA.
We’ve all been here before now.
Grazie
Stephen Crye
January 23, 2014 at 3:26 amHi Rick;
Things like this are why I obsessively save incremental version of all projects, sometimes at 15 min intervals.
MyProjectA, MyProjectB, MyProjectC … MyProjectDZ and so forth.
Not that this helps you now. Sorry.
Steve
Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
Rick Bushell
January 23, 2014 at 3:50 amThanks for that Steve, but I did just that. I saved the intro and 2 different events for the content and 1 for the ending. The problem is when I go to open a file, it doesn’t load or just a bit of it loads and for both I get the warning message, some of the files could not be opened!
Rick Bushell
January 23, 2014 at 4:10 amI just tried to load my intro, nothing loads at all and I get a pop up saying; The following file could not be found in the specified location.
Also this program seems to just get more and more proplems. I’ve scanned, defragged, checked disk integrity etc. I’m at my wits end now. I simply don’t know what to do.Desperate
