VOB Suggestion
Posted by William Quibell on May 17, 2010 at 5:34 pmFunny story… My marketing department lost original footage from a standard def. DVD we sell and show. They now was me to put the movie (with 5.1 sound, multiply languages and subtitle tracks) on a file server to play.
I because Vegas does not support VOB’s, I used an open source program to convert the VOB to MP4 with 5.1 sound twice; Once for English, once for French.
How would you extract all the info from the VOB file?
Jill Baangra replied 16 years, 4 months ago 5 Members · 9 Replies -
Theo Van laar
May 17, 2010 at 6:24 pm‘I because Vegas does not support VOB’s’
There is no need to convert the VOB to MP4.
Just place the DVD in the DVD player of your PC, open Vegas and select FILE-IMPORT-DVD Camcorder disk. If the disk is not copy-protected, it will be imported into Vegas
Theo
William Quibell
May 17, 2010 at 10:59 pmI have the non-encrypted “theatre” version of the DVD. I will try that… Thank you
on a side note I am new to Vegas, I have been using premier pro 2.0 for a little longer then I should have been… LOL
Donnie Rodriguez
May 18, 2010 at 2:13 pmWhat I have done in the past is copy the VOB file (VTS_01_1.vob)from the DVD to a file folder on my computer.
Open Sony Vegas (I’m using 7) and in the explore tab locate the folder I just copied the .cob file to.
Then click on the Views button in the tool bar just below the envelope tool button and make sure the all files box is checked.
When it is the .vob file will show up and just drag it to the video track and edit.
William Quibell
May 19, 2010 at 3:37 pmWhen I try to import the VOB into Vegas two very bad things happen.
First it takes almost 15-25 minutes to import the vob file into Vegas. Then asfter waiting all that time, when I drag the vob into the time line (w/ 5.1 if that makes a difference) the program crashes everytime!!!
I figured this happen because Vegas dose not support VOB files.
Any advise?
Pain is Temporary – Pride is Forever!
Mike Kujbida
May 19, 2010 at 3:53 pm“Any advise?”
Yes, try the method Theo suggested earlier in this thread.
It’s always worked for me. -
Theo Van laar
May 19, 2010 at 4:57 pm‘I have the non-encrypted “theatre” version of the DVD’
From all you told us, I suspect that your DVD is copy-protected…
Theo
William Quibell
May 19, 2010 at 5:53 pmno, no 🙂
The footage is our own. It’s just a 17 minute documentary on how our facility was built. Since we lost the original footage, I have been playing the VOB on a solid state media player from Technovision. But now that we are moving forward to a Doremi file server to play all the documentary we have, I need to create a DCP for everything we have.
I will continue to work on this… thank you to everyone for your assistance.
Jill Baangra
May 21, 2010 at 10:56 pmDownload a program called “FormatFactory” which is free from Formatoz. Use the DVD tp Video Option…rip to AVI with output settings:
Mpeg4(Xvid) and profile: HighQuality and Size.Mpeg4 Xvid files can then be smoothly and easily edited in Vegas
(maybe on XP, you may need to install the K-Lite mega pack to ensure Xvid files can be opened)Jill
