Activity Forums Adobe Premiere Pro Video wont drag from project to timeline in PP CC
  • Video wont drag from project to timeline in PP CC
    Posted by Dan Sawyer on August 11, 2013 at 6:15 pm
    Been working with PP CC since it came out and have had almost no problems. Now I have a head scratcher. I can’t drag a video clip from the project panel to the sequence. The audio comes but the video won’t. All I get is the close hand with a line through it when I hover over any of the video tracks. The clips play fine in the source monitor but still cant drag it from source to sequence either. Tried this with clips from several projects and cameras but no go. Started a new project, different name, folder and footage, still have the problem.
    If I load a saved version of a CC project everything works fine with the footage that wouldn’t work earlier. Fired up CS6, everything works fine.
    At first I thought I might have a problem with the footage but now I don’t have a clue.
    Anybody had this before and more importantly how to fix it????
    John Holowitz replied 8 years, 10 months ago 32 Members · 39 Replies
  • 39 Replies
  • Angelo Lorenzo
    August 12, 2013 at 3:05 am
    Are any video tracks selected/armed on the left of the timeline?
    Can you post a screenshot of your timeline panel?
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Dan Sawyer
    August 12, 2013 at 12:12 pm
    Well the problem seems to have solved itself at this point. The tracks were armed. Started an entire new folder for the project and started everything from scratch and it seemed to work fine. Probably should have done that to start with and I’m sure I probably did something wrong but no idea what it was.
    Thanks for your response and help but as long as it’s working I’m going to chalk it up to operator error and/or ghost in the machine and try to catch up on the half day I lost trying to figure it out.
  • Logan Peter
    September 18, 2013 at 4:50 pm
    Hi Angelo,
    With regard to the issue of not being able to drag videos from the project window to the timeline in Premier Pro CC; I am having that issue. Any words of wisdom on how to fix it?
    Logan
  • Peter Garaway
    September 18, 2013 at 11:24 pm
    Hi Logan,
    In your your audio Source Patching track do you see a little plus sign? If so, right-click on it and select Add Tracks to Match Source from the context menu. You may be seeing experiencing this behavior because your current sequence has few audio tracks than your media your attempting to bring in.
    If this is not the case a screen shot of your Timeline would be helpful.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Bruno Silva
    September 23, 2013 at 10:03 pm
    This may help.
    In your sequence, on the left most column you should see a V1 (left of the Lock Track button). Click that to make sure its highlighted, it allows you to drop video to the sequence.
  • Robert Wiegand
    September 27, 2013 at 8:54 pm
    I have a problem like Logan. P pro does not display any tracks on the timeline, there is no V1 etc, and the selections below the wrench are greyed out. Have any solutions been found?
    Peter Garaway
    September 28, 2013 at 12:15 am
    Hi Robert,
    It sounds like you don’t have a sequence created. Try this
    Peter Garaway
    Adobe
    Premiere Pro
  • Robert Wiegand
    September 28, 2013 at 7:44 pm
    Thank you Peter. I’ve completed a few Ppro projects (up to CS4) in the past and don’t recall ever having to do this. Thanks again!
  • Sylvanus Stephen
    March 10, 2014 at 2:49 pm
    Thank you man, it worked for me
  • Casey Bennett
    August 12, 2014 at 11:04 pm
    Thanks! This helped me. I could create a sequence from the video clip, but couldn’t drag it to the timeline. Clicking the V1 icon to the left of the lock buttons worked for me perfectly. Not sure how or why it was unclicked to begin with!
  • Page 1 of 4
