Activity › Forums › Adobe Premiere Pro › Video wont drag from project to timeline in PP CC
John Holowitz replied 8 years, 10 months ago 32 Members · 39 Replies
Tad Newberry
November 14, 2014 at 12:34 ami started having this problem today…been using it for a year, and it’s different today. i can still do, “new sequence from clip”, and that works, then i can copy and paste the clips from that timeline to another. then i found this thread. clicked a little more on the V1’s, etc., but also toggled the “toggle sync lock” button on and off (never used it before), set it back to where it was and then i could drag stuff to the timeline. go figure…
thanks for helping out a bonehead!
__________________________FCS3 / Adobe CC
3.33 GHz 6-Core Intel Xeon Mac Pro
24GB RAM
ATI Radeon HD 5870
…and a few TeraBytes o’ storage
(then it’s on to PetaBytes, ExaBytes and MosquitoBytes!) -
Tad Newberry
November 14, 2014 at 12:38 ami started having this problem today…been using it for a year, and it’s different today. i can still do, “new sequence from clip”, and that works, then i can copy and paste the clips from that timeline to another. then i found this thread. clicked a little more on the V1’s, etc., but also toggled the “toggle sync lock” button on and off (never used it before), set it back to where it was and then i could drag stuff to the timeline. go figure…
AND, now that i’ve rendered some clips from the timeline and bring them back in, they only have 1 audio track, even though the timeline it was rendered from had 2. wut up wif dat????
24GB RAM
ATI Radeon HD 5870
Gary James
December 6, 2014 at 4:47 amYou sir… Are a genius! Thank you! And thank google… for it is a good thing.
Asa Khan
March 16, 2015 at 1:07 amHi Im having exactly same problem as Dan Sawyer with my timeline and have did exactly the same test but fail.
Kamil Wawrzyszko
August 16, 2015 at 11:11 pmWhat worked for me was saving the project, quitting Première Pro and reopening the project. Come on Adobe – fix this!
Lucas Miller
August 18, 2015 at 5:09 amI’m having the same problem–I get a hand with a strikeout symbol when I try to add video. V1 is activated and I’ve toggled “toggle sync lock” a couple of times. I’ve tried with AE composition and regular footage. I can add audio but not video. Makes no sense at all…
I can create a new sequence and then copy from there but that’s a serious hassle. I have a lot of clips yet to add but I’ve invested many hours in this sequence. Please help!
Tad Newberry
August 18, 2015 at 6:28 amfirst, empty all caches.
delete all previews.
that will PROBABLY do it.
keep us posted! 😉thanks for helping out a bonehead!
24GB RAM
ATI Radeon HD 5870
Lucas Miller
August 18, 2015 at 2:54 pmDuh, there are TWO things that highlight and say V1; one is “source patching for inserts and overwrites” and the other is “toggle the track targeting for this track.” It’s to the LEFT of the lock symbol. I had none of the former highlighted and so no video would load.
Having said that, now that I deactivate the one on the left, I can still load video onto that channel. I’m confused but, as long as it’s working, satisfied.
Thanks, though!
Andrew Bird
January 20, 2016 at 2:00 pmDitto!
Empty audio tracks. Target Track highlighted (of course!). Caches, emptied. Preferences Trashed. Sudo:Purged. Restarted.Workaround was to place footage into a separate timeline then cut/paste it into my current assemble.
Obviously a temporary fix and we’ll se how that works out when footage comes in!
