Activity Forums Adobe Premiere Pro VHS Capture to PP CS6 – Hardware Advice Needed
  • VHS Capture to PP CS6 – Hardware Advice Needed
    Posted by Phil Lochner on March 28, 2013 at 9:18 pm
    Hello everyone,
    I’m looking for some purchasing advice. I have 50+ VHS tapes that I would like to convert to digital using Premiere Pro CS6 on my i7 / GTX 470 / 12GB / Windows 7 x64 system.
    I’m a pretty proficient CS6 user and have been in video production for several years. However, I haven’t touched VHS in many years, and even then years ago the whole prosumer-level analog to digital process required special hardware, and tons of expensive disk space and memory. I didn’t have the hardware or budget years ago, but I do now.
    I don’t even have a VHS player at home anymore, so I’ll have to buy something. My source tapes are a mix of VHS and some SVHS, so ideally the VHS device will be capable of also playing SVHS.
    Many of these VHS tapes have been digitized already with ~$50 consumer USB (“so easy to use, one click and go!”) based devices from about 8 years ago. The resulting quality was atrocious and thus, I want to redo them. Therefore I don’t want to use “home user” hardware/software that most likely uses inferior codecs and poor compression algorithms. I’m looking for something that interfaces directly with PP’s capture features.
    I don’t need any special interface to jog / set capture points / control the VCR with PP, I figure I’ll end up doing a raw capture of the entire tape and editing it down from there (hooray for cheap TB drives!).
    Can anyone offer any advice as to what VCR or specific capture device I should be looking at?
    Thanks in advance!
    Johnny Tintor replied 13 years, 1 month ago 3 Members · 4 Replies
  • Alex Gerulaitis
    March 28, 2013 at 10:27 pm
    Grass Valley ADVC-110 has been doing a lot of these conversions in the past decade. Captures into a DV stream.
    Alternately, you could capture into H.264 at variable bit-rates, giving you more control over quality, with something like Video Recorder, or H.264 Pro Recorder.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Johnny Tintor
    April 2, 2013 at 7:39 pm
    I’d recommend using any of the pro JVC series 22 SVHS decks. The BR-S822DXU provides excellent playback quality and features a built in time base corrector and digital noise reducer. Use the component analog out and run the signal through a Matrox MXO2 Mini Max as it includes Component, Composite, S-Video and HDMI inputs. Capture either uncompressed or directly to H.264 for archival purposes. You can use the free productivity app: Direct H.264 capture. https://www.matrox.com/video/en/products/mxo2_mini_max/productivity_apps/
    Remember to use high quality cables and make sure the deck heads are clean.
    I’ve experimented with many different setups and this one seems to provide the best results.
  • Phil Lochner
    April 2, 2013 at 8:37 pm
    The VHS tapes I need to digitize were for the most part, not professionally shot – they’re tapes from schools, old instructional videos, some home movies, things of that nature.
    I don’t want to spend too much money on equipment to digitize what in the end is crappy footage. However I do want to digitize crappy footage in the highest possible quality, if that makes sense.
    Thank you both for your advice. I think I’m going to start small and spend $200ish on a digitizing box and see what kind of quality I can get with it using a consumer VCR. Not sure how I’ll handle the SVHS tapes yet though.
  • Johnny Tintor
    April 2, 2013 at 9:01 pm
    In that case, the canopus advc 110 is the best bang for the buck. You can find them on eBay for $100-$150. If you can find a cheap external TBC to throw in between the deck and the canopus, your results will be pretty decent.
