Activity Forums VEGAS Pro Vegas Pro vs Vegas Pro Suite
  • Graham Bernard
    August 10, 2020 at 2:17 pm
    OK, have you switched back on the MOV/ QT option in Deprecated Tab?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Roger Bansemer
    August 10, 2020 at 4:21 pm
    I’m not finding it. Here’s what my Particle Illusion render screen looks like.
    Roger Bansemer – PaintingAndTravel.com
  • Graham Bernard
    August 10, 2020 at 5:14 pm
    [Roger Bansemer] “I’m not finding it. “
    In VP17 open Preferences and then click on the Deprecated Tab and make sure QT/Mov is selected.
    * Grazie
  • Roger Bansemer
    August 10, 2020 at 6:56 pm
    Thanks for helping me Graham.
    This is what I have on that tab and the quicktime one was checked.
    So, still no luck.
  • Graham Bernard
    August 10, 2020 at 8:34 pm
    Let’s backup the Bus here….. That render menu is part of what?
    * Grazie
  • Roger Bansemer
    August 10, 2020 at 8:47 pm
    Thst render menu was the render menu for the standalone version of particle illusion.
    It needs to be rendered out in particle illusion so I can import it into Vegas 17.
    It renders out fine and I can import it but it is not transparent.
  • Graham Bernard
    August 10, 2020 at 9:53 pm
    [Roger Bansemer] “Thst render menu was the render menu for the standalone version of particle illusion.”
    Ah, right! I know the standalone from years ago. I’m guessing that VP needs to have the ALPHA channel in a way that it recognises. Have you had success doing this before? Or is this your first attempt? There’s obviously an ALPHA Flag Vegas ain’t seeing. Please do a MediaInfo on that MOV. Yes?
    * Grazie
  • Graham Bernard
    August 11, 2020 at 4:29 am
    Just for YOU, I d/l the FREE SA pI and I have to say it works fine back in VP17:
    So, what are your thoughts?
    * Grazie
  • Roger Bansemer
    August 11, 2020 at 12:44 pm
    I sure wish I knew what I’m doing wrong.
    Here’s what I’m getting.
  • Graham Bernard
    August 11, 2020 at 12:47 pm
    [Roger Bansemer] “I sure wish I knew what I’m doing wrong.”
    Roger!!! Look at the thread I started in your honour. The answer is there. ?
    * Grazie
Page 2 of 3
