Activity Forums VEGAS Pro vcr to Vegas 12
  • vcr to Vegas 12
    Posted by Jack Gill on February 12, 2018 at 1:07 am
    Trying to feed a vcr into Vegas 12. have a Canopus ADVC100 between the vcr and my computer. The Canopus is attached to my computer via Firewire. Vegas is not recognizing the vcr. Help, please.
    Jack
    John Rofrano replied 8 years, 7 months ago 4 Members · 20 Replies
  • 20 Replies
  • Francois Pénzes
    February 12, 2018 at 1:57 am
    Hi Jack
    First thing to check, is your OS recognizing the Canopus ‘cuz if the OS is not seeing the Canopus then no software will.
    When your done checking, please post machine and OS specs.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    \’\’When the cutting stops, the editing begins…\’\’
  • Jack Gill
    February 12, 2018 at 2:22 am
    Francois,
    I’m not much of a techie. How can I tell if my computer is seeing the Canopus?
    I have a custom PC with an ASUS P7P5SD (green) motherboard, an Intel quad CPU,
  • Francois Pénzes
    February 12, 2018 at 3:18 am
    Hi Jack
    I will assume that your are running Win 10.
    Go to Start/Settings/Devices and under Other Devices your Canopus should be showing.
    Cheers !
  • Jack Gill
    February 12, 2018 at 3:42 am
    I am running w 7. Does that make a difference. Following your directions I couldn’t get to where I wanted to go.
    Jack
  • Francois Pénzes
    February 13, 2018 at 12:57 am
    Hi Jack
    This is definitely not the best explanatory video but it will tell how to get to device manager in Win 7.
    https://www.youtube.com/watch?v=IiRNvnBJWq8&ytbChannel=Theofficialwindows7
    Cheers !
  • Jack Gill
    February 13, 2018 at 3:02 am
    Ok. Here is where I am.
    1. Grass Valley no longer supports my canopus 110
    2. In my Device Manager I have an active firewire
    3. A release from Grass Valley declares that the 110 has been tested and absolutely works with W 7
    4. Perhaps I don’t understand how to make the connection to my Vegas 12.
    Jack
  • Francois Pénzes
    February 13, 2018 at 11:24 am
    Hi Jack
    The problem seems to be with the way your Canopus communicates with your computer. Make sure that the hook-ups are correct. I have included a link to a user manual for your Canopus in case you (or any others coming here) need to do some troubleshooting. Have a good read, even the best of us miss something…sometimes. (Don’t forget about those pesky hard to read dip switches, page 16)
    https://www.bhphotovideo.com/lit_files/71386.pdf
    Once you will have solved your communication problem with your computer, Vegas should recognize it straight off.
    P.S.: When you get it working (and it will) please come back and let us know how you did it, so that the next person can benefit.
    Cheers !
  • John Rofrano
    February 17, 2018 at 3:12 am
    I thought I had read that Windows 7 has a problem with some Firewire devices requiring that you use the “Legacy” Firewire drivers. Here is an article about it:
    Changing to the Legacy IEEE-1394 (Firewire) Driver in Windows 7
    It might have something to do with it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Jack Gill
    February 17, 2018 at 4:24 am
    John, Thanks so much for your input. I am always delighted when you jump in to help. Jacck
  • Jack Gill
    February 19, 2018 at 7:36 pm
    John,
    Followed directions for loading legacy, but nothing so far. Perhaps I don’t understand how to make the connection to Vegas 12.
    Jack Gill
